Hi All
My A3 tdi 150 quattro was in at the dealer's today to have some issues checked.
1) the electronic handbrake has been intermittently sticking on. They "reset" it and so far it has been working ok this evening.
2) the gear selection is very notchy/clunky in 1,2,34 and reverse. They said this is normal. Is it?? What can I do about it??
3) the speed signs on the satnav are sometimes showing the wrong speed limit. They asked for an extension for some connection or something so they would display properly. I need to test this but does that sound correct?
4) the satnav (and Speedo area backlight) were intermittently flickering. I think it was the brightness flickering. They couldn't find any fault so I need to try and video it happening. Is this a common issue?
5) there is sometimes a very faint whine noticeable on a smooth quiet road surface when just keeping the accelerator on enough to keep your speed. It goes away if you lift the throttle. They said it was the haldex unit and it was normal. Is it??
I have noticed that since I got the car back, the satnav displays a 2d map and it doesn't navigate. Is there a setting I need to change to get it to work again?
Dave
Dave
