Setting car up properly.
Fifequattro Mar 19, 2010
  1. Fifequattro
    Fifequattro New Member
    14
    Right, i`ve come to the conclusion that my car is just a thirsty ******, no sooner have I filled it up it seems to have disappeared! :faint:- what would be the best way to get my car setup so that its running properly? use a rolling road or maybe vag-com? - thanks for any advice guys
  2. j033y
    j033y Member
    198
    What engine is she? how thirsty? MPG she does, and i mean actual not what the DIS says.
    How many miles do you do per journey? long or short?
    Vagcom wont help you set it up, a remap would, but i guarantee unless its a diesel it will get worse!
    Only thing you could do on Vagcom is throttle body alignment! dependant on engine i think!
  3. Fifequattro
    14
    1.8 T quattro - I know that with it being quattro it will be heavy on fuel - dont know exact mpg, I go by the dis display cos my fuel gauge isnt working just now - the dis mpg goes down in increments of 5 mpg and just seems to disappear lol! - I dont leather the car either and my journey to work is a 12 mile round trip and the occassional motorway run - filled the car up today with 20 quid, turned on the car , dis said 130 miles, pulled away from the forecourt and immediately to 90 miles!
  4. j033y
    j033y Member
    198
    I think the DIS is instantaneous, so if you boot it it will drop like you say to 90 miles in tank left, but iif you were gentle after that it would probably go up!
    How many miles to £20, i would expect you to get around 115 miles for journeys that short. If it does that, personally i think thats ok.
  5. Fifequattro
    14
    See when the dis says 0 miles left, how many miles will be left in the reserve tank then? how do yo accurately work out mpg? I have seen 145 - 150 miles to 20 quid and that was v power, does this make a difference? maybe my car is running ok I am just constantly driving with one eye on the dis lol!
  6. AJB Audi
    AJB Audi Member
    77
    24
    [my journey to work is a 12 mile round trip]
    I think that's your problem - two start ups from cold with only a six mile run each time. If that's the bulk of your motoring I think you'd struggle to find any car that would deliver good mpg figures.
  7. auroan
    auroan Active Member
    1,669
    Whats the issue with your fuel gauage ? If it's an issue with the sender then the dis computer might be reading wrong as well.
  8. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,386
    112
    145-150 is better than i get for £20 and mines the 18t fwd and a heavy cab so i guess ur ok wanna swap? lol
  9. Fifequattro
    14
    Fuel gauge is sticking, turn on the car and it just sits as if the car has a full tank of petrol - you can see the needle flickering when you turn on the ignition - any ideas? someone did mention fuel sender
  10. AU01 A4
    AU01 A4 Member
    211
    my long time Avg for mpg is about 28mpg 60% Mways and rest short runs,
  11. Fifequattro
    14
    Ffs!:sadlike: temperature gauge had decided to act dodgy now, what is going on with my car!? guessing its the coolant temp sensor or thermostat, but, could it be a faulty instrument cluster? seems to be a bit of a coincidence that both the fuel and temp gauges are knackered!
  12. technics100
    technics100 Active Member
    850
    25
    Fill the tank and reset your odometer, drive a few hundred miles and then fill it up again, you can work out your actual mpg from miles covered bs fuel used.
  13. J7USS
    J7USS Shuddup Foooool!!
    3,737
    77
    145 + on £20 V power..:faint:
    Im Jealous!!
    Ill be lucky to get 70mls to £20 these days but I suppose that because I probably only do 3mls between journeys.
    Going to give it a scan with my VAG com tomorrow now though because im starting to get para its drinking faster and Im hardly using it.
  14. Nutkin
    Nutkin Member
    830
    gettign a full service and a few pipes fixed got me up to 340 miles a tank on a 190 qs.
  15. silversurfer
    silversurfer Member
    223
    I get about the same out of my 190 Quattro
  16. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,811
    54
    Stop driving it like you stole it and take off the lead shoes! :icon_thumright:
