Servicing interval reset
Discussion in 'A4/A4 cabriolet/S4 forum(B6 chassis)' started by Caesium, Oct 27, 2006.
  1. Caesium
    Caesium My BM is fixed!
    May 26, 2004
    4,879
    Is there any way to do this? I don't want to change the car to fixed servicing unless I have to but my next service will be my last Audi one, as I can't bear the 70 quid per hour labour charge when I can do a better job myself.
  2. Advert Guest Advertisement
  3. timps
    timps Shakersville
    Oct 2, 2005
    235
    I have reset my Audi Variable Service no problem.
    You will need full VAG com (you have to save adaptations but shareware VAGCom does not let you do this).
  4. dstech
    dstech Member
    Dec 3, 2003
    247
    You don't need vag-com to do this.
    Here's how to reset the service reminder on a B6:
    -Turn car off
    -Hold "Wrench" Button on Console
    -Turn on car (don't need to start)
    -Press Trip Odometer Reset (0,0) while still holding Wrench
  5. Caesium
    May 26, 2004
    4,879
    Does this set the car to fixed servicing?
  6. Caesium
    May 26, 2004
    4,879
    What is that and where would i get it from? PM me if its not suitable for open discussion:angrymod:
  7. timps
    timps Shakersville
    Oct 2, 2005
    235
    You do need VAG com if you want to keep it on AVS (Audi Variable Servicing) & A4Quattro wrote : "I don't want to change the car to fixed servicing unless I have to".
    The method you indicated resets it to fixed servicing at 10000 miles only & not AVS.
  8. timps
    timps Shakersville
    Oct 2, 2005
    235
    You have 2 options
    1) Buy an official lead from http://www.ross-tech.com/ full Vagcom is included with the lead.
    or
    2) Buy a cheaper lead from eBay or http://www.talktomycar.co.uk/ and then buy a full Vagcom licence from ross-tech (this is the cheaper option but you don’t get the same backup).
    The Vagcom shareware is free to download & you can do quite a lot with it and a cheap eBay cable but you will need the full version to reset AVS.
  9. Caesium
    May 26, 2004
    4,879
    Seems like a lot of dough to reset an indicator, 399 dollars for a lead!!
  10. timps
    timps Shakersville
    Oct 2, 2005
    235
    It does a lot more than just reset the service indicator.
    I bought mine as a fault code reader and to alter some settings.
    My eBay cable cost £15 and about £50 for the VAGCom licence for my A4 B6 I recouped that on doing my own service and being able to rectify a fault code but I take your point its not cheap.
  11. dstech
    dstech Member
    Dec 3, 2003
    247
    Sorry I missed that originally timps.
    Ya, get the Vag-com software it works great. I have the latest Ross-tech USB cable and it works great.
    If you don't plan to do much with vag-com and your car then just do the eBay route and use the shareware version of vag-com.
    There is a cracked version of 303 floating around the internet but obviously if you want to use their software you should buy it.
