Serviced, now a pressurised oilcap???
Custard Dec 12, 2009
  1. Welly
    Welly VX220 SC Driver :)
    10,696
    128
    Meh, anything that collapses under vacuum pressure has an inherent problem in my opinion!
    We're not talking about running massive amounts of extra boost from the blower to cause TIP collapse, and extra couple of PSI has been known to cause it. All it would of taken to resolve this problem was a few metal supporting rings built into the TIP.
    I don't personally think it was designed to be as good as it could be, which in my opinion is a design flaw. Inept designers? Maybe. I think things should be designed to withstand far more than they are put through on a day to day basis.
    Anyway, you have your opinion. I have mine. :)
  2. badger5
    9,471
    1,988
    how?
  3. Prawn
    11,510
    3,423
    because the pipe was already split Bill. Dave putting a plug in it did effectively nothing, as he was plugging the open end of a pipe already split further up it's length.
    that's not to say that his crank case pressure hasn't been caused by a blockage elsewhere in the PCV system, as I said above.
  4. badger5
    9,471
    1,988
    PCV is a t-piece, the stumpy end of which is the one way valve for manifold vac
    something got blocked else it would not build up the pressure. (some kinked pipe perhaps)
    blocking the vac pipe which goes to the manifold should not have made any difference to crankcase pressure. it would free vent into the TIP on otherwise std pipework, unless that pipework had collapsed or kinked.
  5. Prawn
    11,510
    3,423
    thanks Bill, you've just confirmed exactly what I've been saying for this entire thread, although nobody seems to believe me.
  6. auroan
    auroan Active Member
    1,669
    Anyway back in the real world there is something called a "cost/price ratio" You want something made to a higher spec, then you will have to pay more. Audi designs are spec'd to a given limit, going over board on the capability of components when its not needed would only either eat into profits or drive the price up.
    So fancy paying more for your S3 ?
  7. badger5
    9,471
    1,988
    as described its a weird one..
    stopping it breathing is the only way I can think it could presurise the crankcase, which is collapsed or kinked pipe most likely..
    bizarro
  8. Frankus
    Frankus Old but built for speed!
    97
  9. Erikn89nl
    Erikn89nl Well-Known Member
    738
    282
    5 year old thread, revived with a quote, and nothing else. Mystery to me.
    JamieT_a3 and A3-Lee like this.
