Service on DIS
A3_TOBES Aug 8, 2006
  1. A3_TOBES
    A3_TOBES Member
    160
    What kind of pre-service warning does the DIS give you when the service is almost due ???Days/???miles.
    Also to check it yourself do u pull or push the button? with ignition on or off?
    cheers :)
  2. h5djr
    9,438
    1,757
    The indicator shows Service in XX miles XX days. When the service is due it puts up the word Service! To check yourself you have to pull the right hand side button briefly with the ignition switched on.
  3. Eeef
    Eeef Lord of War
    1,607
    Mine came up at 1300 miles. You can manually check by either pulling the right hand whatsit on the dash, or go through the Menu of the DIS.
  4. silver75
    silver75 Big Ron
    3,265
    this might be a dumb question but when the "service!" message comes up does that mean service right now or could you leave it a couple of weeks as I currently have this message up and havent had the chance to call any garages for quotes etc
  5. Eeef
    Eeef Lord of War
    1,607
    No, it counts down. So it starts at 1300 miles then increments down in 100 blocks.
  6. Vertigo1
    Vertigo1 Well-Known Member
    3,609
    705
    Only if you have a menu on your DIS :)
  7. marriedblonde
    marriedblonde Active Member
    4,371
    You get a 1000 miles after the service now indicator. So depending on your daily commute you should be ok.
    J.
  8. A3_TOBES
    A3_TOBES Member
    160
    Cheers guys for the replies.
  9. Eeef
    Eeef Lord of War
    1,607
    eh? You no got a menu? Press the button on the underside of the right hand stalk?
  10. Vertigo1
    3,609
    705
    Nope, mine's a 53-plate car and obviously has earlier software. There's no menu for the DIS on mine :(
    There are also other subtle differences, such as the range display doesn't have the little fuel-pump icon to the left of it.
  11. Eeef
    Eeef Lord of War
    1,607
    Want to upgrade to an 05 with a menu option :)
