Service Indicator
Discussion in 'A3/S3 Forum (8L Chassis)' started by Baza, Sep 23, 2003.
  1. Baza
    Baza New Member
    Aug 16, 2003
    Hi all,
    Does anybody know how to reset the server indicator on an S3...? Ive just had the car serviced but they didn't reset the counter so its now flashing that it requires a service. Ive looked everywhere and tried the 2 dials without much luck...
    Baz
  2. Advert Guest Advertisement
  3. Jonmurgie
    Jonmurgie Member
    Mar 6, 2003
    Did you get it serviced by an Audi Dealer? If so then take it back there and they will sort it for you...
    If not then I'm sure I heard of a way on one of the forums so maybe someone can point you in the right direction....
    Jon
  4. PaulBelsham
    PaulBelsham Member
    Jan 9, 2003
    The drivers handbook explains how to do it yourself, cant remember off the top of my head how to do it though, what I do know is that it isn't something you can accidently do, it requires several pushes and pulls of various buttons.
  5. Jonmurgie
    Jonmurgie Member
    Mar 6, 2003
    From page 72 of the Owners Manual:
    Resetting service indicator
    The display is reset by the Audi dealer after the service has been carried out.
    If the service is not performed by an Audi dealer, the display must be reset as follows:
    1. Switch off ignition
    2. Press button (2) and hold while switching on the ignition. The display should now read "SERVICE!".
    3. Press and hold button (1) until the word "SERVICE!" is cleared from the display.
    Notes
    Do not clear the service indicator between services - otherwise the display will be incorrect.
    The information in the service indicator remains intact if the battery is disconnected.
    BTW, button (1) is the left hand button (clock) and button (2) is the right hand button (trip).
    That should sort you out /ubbthreads/images/graemlins/smile.gif
    Regards
    Jon
