Service indicator - how to reset it??
Donald_MacIver Nov 17, 2006
  1. Donald_MacIver
    Donald_MacIver Member
    214
    I know this is a popular subject, but i have tried searching for previous posts on this subject, but it seems it is not the same process for all audis. Anyone know of the process required to reset the service indicator on my B5 A4. I just had it serviced but it is still flashing up Insp1.
  2. SteveS
    SteveS S6 avant
    691
    i had a 2000' a4 tdi and it said in the owners manual how to do it. think it was near the back.
  3. Danielson
    Danielson Member
    704
    If carrying out your own service then to remove the anoying service light on start up then try this.
    Press and hold the right button. (odometer reset)
    now switch on the ignition
    (oil lamp will not flash, but on at all times)
    press the right button again
    (insp is now displayed)
    pull left button. (clock set)
    (------ are now displayed)
    Pull left button again
    This works on my A4 tdi (110bhp) but should work on all.
    this also works on my 98 A4 1.8T
  4. Donald_MacIver
    214
    Thanks for the info, will give this a try.
  5. Randomjim
    Randomjim Active Member
    2,752
    Worked for me, i've been meaning to do this for ages
  6. Danielson
    Danielson Member
    704
    its funny coz ive been meaning to do it for the last 3 years and done it this morning. nice i like.
  7. Beerzo
    Beerzo Masa'warty 3200... Talk To Me!
    1,242
    I have access to full Vag-Com if you need anything done but being from Lewis your a very loing way from Greenock
  8. Padwick
    Padwick A3 2.0TFSI Quattro
    10
    Will this work on a 2001 diesel A6? I haven't seen any posts about it in the A6 section. Thanks.
    Pat.
  9. Danielson
    Danielson Member
    704
    i dunno, but you could give it a try. nothing to lose
  10. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
    i did the one on my Dads 99 T A4 the other day but i had to press in both buttons on the dashboard and whilst holding them in put in the key and start the car none of the other ways seemed to work not even the way it said to do it in the manual.
  11. Padwick
    10
    Cheers. I can't mess up anything by trying then can I?
  12. simonwjones
    simonwjones Member
    365
    doesnt resetting it this way have some effect on wether you are avs or not?
    Simon
  13. stapo69
    stapo69 All hail the mighty quattro!
    969
    Just did this on my 1998 S4, worked a treat.
  14. Markey
    Markey Active Member
    2,175
    my left button dont pull :(
  15. Siena
    Siena Active Member
    2,626
    The manual reset procedure only works on cars approx. 1997 on. Earlier cars need VAG-com or similar.
  16. Andyb5tdi
    Andyb5tdi B5 1.9TDi AFN
    61
    15
    Thanks, worked perfectly on my 1998 A4B5 1.9 TDI.
    Is it a set mileage for when the oil/ inspection flashes up or is it more complex than that?
    Andy
