Service in 'Menu' doesn't show days or mileage
DarkBunny Jul 29, 2013
  1. DarkBunny
    DarkBunny Active Member Team Sprint Audi S3
    497
    112
    43
    Is this normal?
    When I go into the menu system and go into Check - Service, it's just got --- next to days and --- next to mileage.
    I've been told that its running the 2 year service plan... Shouldn't something show up?
  2. Napbree
    Napbree Member
    136
    13
    Give it some time to re-calibrate, i'm assuming you've just had a service?
  3. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    If you value your car in anyway change to the fixed interval.
  4. DarkBunny
    497
    112
    43
    Yes - only picked her up at the weekend and it had been serviced at the franchised dealer I bought it from.
  5. DarkBunny
    497
    112
    43
    Think I will (how please?). My old motor was running a 6 month or 4,500 mile service so I'd rather have it done more regularly :whip:
  6. A3Kent
    A3Kent Well-Known Member
    1,571
    249
    This is normal behaviour after a service then. Leave it a while and eventually you'll get the days and miles back.
    DarkBunny likes this.
  7. hades-
    9,482
    646
    can take around 500 mile to show again
  8. DomH
    DomH Active Member Audi S1
    211
    54
    You should be able to knock the light from long life to fixed interval without using a computer/VCDS, but if you want to reset it using long life you would have to use a computer! Search on the forum there will be plenty of threads about resetting service interval, can't remember off the top of my head
