Service due which oil ?
ex_scoobydoo Nov 15, 2009
  1. ex_scoobydoo
    ex_scoobydoo Member
    179
    hi
    ok my car is due a service its done just over 120000
    its had all long life services in the past but i plan to service around every 6 to 7 now i own the car, i will get a genuine oil filter, but what oil is best to use and what grade, also i plan to change the spark plugs, any sugestions on which are the best to use, should i consider anything else apart from what i have said above?
    here is a dumb question aswell
    how does the car know the service has been done, to enable the service light to go off on the dash.
    thanks.
  2. rossbrownlee
    rossbrownlee Ross_S4
    719
    you can use the buttons on the cluster to reset service counter, it is in the user manual.
    i am about to service too, using standard ngk pfr6q plugs and was planning on using castrol edge 5w-30 oil.
    did fuel filter today, couldn't believe the colour of the sh.. that came out the old one!
  3. ex_scoobydoo
    ex_scoobydoo Member
    179
    fuel filter thats an idea i will replace that also, i have just bought the car so im not sure tbh when that was last changed.
  4. grathies
    grathies More Points Than Portsmouth FC
    1,343
    I use Quantam Silver fully synthetic which I get from my local VW dealer (used to work there)
  5. grathies
    1,343
    Also fuel filter isnt a usual service requirement as far as Im aware on petrols, on diesels they are as the water content can mess them up quite quickly
  6. rossbrownlee
    719
    true but i don't know all of the service history of this motor before i got it...
  7. grathies
    1,343
    Thats fair enough, but if youve got **** and water in your fuel system, youll know about it!
  8. m444ty p
    m444ty p Member
    140
    How many litres of oil do they hold?
  9. S3 HODGE
    S3 HODGE Brown passenger seat.
    1,200
    Buy the Quantinum stuff....I used a 5 Litre bottle on the S3 and had a little left over so im guessing you should get 5 Liters to be on the safe side.
    Hope this helps.
  10. grathies
    1,343
    About 4.5litres with an oil filter change as well I belive
  11. oilman
    oilman Active Member
    339
    26
  12. ex_scoobydoo
    ex_scoobydoo Member
    179
    would comma 5W 30 SEMI SYNTHETIC be ok for services around every 7k
    i dont see the point in buying expensive longlife fully synthetic oils when i dont plan to do longlife services.
    if someone could advise please as the service is due tomorow.
    thanks
  13. oilman
    339
    26
    That should be fine for changes at 7k, don't leave it any longer though
  14. ex_scoobydoo
    ex_scoobydoo Member
    179
    great stuff
    thanks for the help :)
  15. god_thats_quick
    2,507
    After advice from Opie some time ago I've been using the below, it's the correct spec and just about the best oil you can get. It's not that expensive if you buy when there's a special on like there is now either:
    Motul 8100 X- lite 0W-30 Gasoline and Diesel engine oil 100% Synthetic – Ester Based
  16. and32
    and32 Member
    42
    i use millers fully synthetic its good stuff, made my car a lot quieter
  17. subby
    subby Member
    126
    Its what i use and it is supposed to be the best oil you can get. However whether the difference would be noticed to halfords special is another matter. Its nice to you you've done the most you can to prolong the life of the engine though.
  18. oilman
    339
    26
    It is very good oil indeed, but you would not notice the difference between it and cheapo stuff. Well not until a few thousand miles down the line when things start going wrong if you've been using basic stuff
  19. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,823
    107
    What oil is the better option for a rebuilt up rated engine?
    I am using the quantom stuff at the moment... but not sure its the best i should use
  20. oilman
    339
    26
    [FONT=Trebuchet MS, sans-serif]I would use a good 5w-40 synthetic and you will find those through the link below.[/FONT]
    [FONT=Trebuchet MS, sans-serif]http://www.opieoils.co.uk/c-656-5w-40.aspx[/FONT]
    [FONT=Trebuchet MS, sans-serif]Out of those, the best ones are the Silkolene Pro S, Motul 300V, Redline and Gulf Competition. With the mods done, it's not worth using a lesser oil. Quantum is pretty basic stuff, more about meeting specs than performance use.[/FONT]
  21. kachnak
    kachnak Active Member
    119
    45
    Hello,
    What type of motor oil is recommended for audi s3 1999?
    I can not find any label in motor space.
    Thank you
  22. oilman
    339
    26
