'service due' on dash
vw754 May 3, 2014
  1. vw754
    vw754 vorsprung Durch Technik
    2,345
    58
    My a4 b8 is displaying service due on the instrument/dash..........in the car menu it still shows 9000 miles before a service is due,tried reset via vcds but no joy,anyone else had this issue?
  2. johnny161171
    johnny161171 Member VCDS Map User
    71
    It will probably be inspection service due which won't reset just by doing basic reset you would have to reset the values in 4 different channels, I would wait until your 9000 is up and then reset oil and inspection
  3. vw754
    2,345
    58
    how do i reset inspection.....? 9000 miles........il be waiting a while,i dont do more than 6000 miles a year lol
  4. Audi Dynamik
    Audi Dynamik Well-Known Member
    2,218
    308
    When does it say you need an oil change on the car menu ?
  5. vw754
    2,345
    58
    in 9,000 miles......thats around 1 and 1/2 years of driving for me
  6. Audi Dynamik
    2,218
    308
    :laugh: You might aswell bike it everywhere !
    Has the amount of days run out ?
  7. Zafi
    Zafi Well-Known Member
    1,282
    320
    There are two sets of miles/date on the display:
    Next oil change - this is the one that can be reset by scrolling down on the MMI and clicking YES
    Next service - this is the one that the dealer (or VCDS user) resets
    So what are the two sets of miles/dates reading?
    Google tells me to reset the lower display...
    With the ignition on.
    click on address '17-Instruments' and then select 'ADAPTATION'
    Go to the 'CHANNEL' box and change the number in it to '40'. Click on 'READ' then in the 'VALUES' box, change the value to '0'. Click 'TEST' and then 'SAVE'. A box will appear to ask you if you are sure, click 'YES'
    Carry out this same procedure for the following channels, AND IN THIS ORDER;
    40, 41, 53, 55, 02
    when complete, exit VCDS by clicking 'DONE, GO BACK' and then close the application.
    Switch the ignition off and then back on. If you've got the sequence above correct, the light will be out.
  8. johnny161171
    71
    Like that one
  9. vw754
    2,345
    58
    i read somewhere to click ''delivery inspection'' ive done that and its sorted it.........thanks
  10. ss
    ss Member
    42
    did this work for you?
