seriously baffling problems
superkarl Aug 25, 2011
  1. superkarl
    superkarl MAN OF STEEL
    9,423
    2,382
    hi, i really cant get to the bottom of this, but what fuel do i put in my S3??
    ive heard it could be the actuator
  2. Reesy
    Reesy Well-Known Member VCDS Map User
    3,640
    148
    Hi mate, first of all is it a genuine s3, or is it a different engined a3 that you have stuck the bumpers and badges on?
  3. Westy
    Westy Well-Known Member
    17,443
    1,103
    Karl what fuels have you tried so far? It sounds like it could be the actuator.
  4. Reesy
    3,640
    148
    If you are having 'baffling' problems mate, that's the exhaust rather then fuel..
  5. superkarl
    9,423
    2,382
    its a genuine 5 door S3 with the AGU engine.
    i first tried bp ultimate diesel, but it didnt seem to like that. so i then heard about these nos fuel additives that double the horse power, so i put about 5 of them in. it DEFFO went alot faster, but it didnt last long
  6. Westy
    17,443
    1,103
    I dont think so mate as Karl cut all the baffles out of his backbox :think:
  7. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,161
    1,121
    No VCDS results, No Help............Wait. Its turned on right?
  8. superkarl
    9,423
    2,382
    :whistle2:
  9. Reesy
    3,640
    148
    I've used them before as well, I think i read somewhere that you can use them instead of petrol for maximum BHPs.
    The problem with your fuelling is that you are using BP diesel, when you should be using V-power diesel, as that gives you more BHP and V power points.
  10. Westy
    17,443
    1,103
    Try chip fat as I've heard you can run the S3 on that.
  11. Reesy
    3,640
    148
    That'd be your problem then mate, the s3 is meant to come with a 1.8t engine.
  12. Reesy
    3,640
    148
    I use that instead of castrol oil as it's cheaper.. Oil's well that ends well?
  13. ScottD3
    15,161
    1,121
    V Power?
    DOes the V stand for virtual, as in virtualy no difference in power?
    May be thats the issue, its all virtual?
    Is there a P(Placebo) Power as well?
  14. superkarl
    9,423
    2,382
    yeh that makes sense! il try that tomorow! im just waiting for delivery of my new actuator
    does anybody else have any concerning problems, ive been a mechanic for a week now and can pretty much solve anything
  15. superkarl
    9,423
    2,382
    its not a 1.8t. its an AGU 3.2 v6
  16. Westy
    17,443
    1,103
    I've removed my rear springs to get that slammed look but the car feels very strange when going round bends now. Any ideas?
  17. Jay A3
    Jay A3 #because Racecar Team Daytona Audi A3 Manual
    2,126
    354
    Thats where you've gone wrong Karl, is the V badge red?
  18. Reesy
    3,640
    148
    You can't just remove the springs mate, the shocks have to go as well..
  19. superkarl
    9,423
    2,382
    yes thats easy, dont forget to remove the front ones to balance it out. should be fine then.
  20. Solly
    Solly My XBL GT - ii solly uk ii
    927
    what engine oil are you using? 20w50 mineral?
  21. Reesy
    3,640
    148
    You want to take that back to wherever you bought it, either that or try and fit a 206 s3 front end on it...
  22. Reesy
    3,640
    148
    Karl, do you think it could be your Rods? I heard they go when you put the key in the ignition?
  23. Jay A3
    2,126
    354
    If you take the wheels off and put the car on bricks with the slammed look, it will give the impression of it floating...
  24. Sandip
    2,440
    91
    Yeah common issue, you need to uprate your rear anti roll bar, i've got a special 8mm bamboo cane and springs out of a BIC pen
  25. ScottD3
    15,161
    1,121
    I read that having a smaller steering wheel will help you turn quicker and sharper.
    I was unable to get a steering wheel as small as I wanted so I used a set of mole grips.
    The trouble now is that I find it very hard to do a full roation.
    can you offer any help or advice?
  26. superkarl
    9,423
    2,382
    those 206 front ends look good dont they!
    i did an oil change the other day actually. i had loads of oil left from changing it on my 2 stroke crosser, so used the rest of that.
  27. superkarl
    9,423
    2,382
    scott - i also tried the molegrip mod, but found donuts really hard. so i switched to using a really big jubilee clamp, its just like a small sporty steering wheel, plus, i can now do most of the stuff ken block can do
  28. Reesy
    3,640
    148
    Hello buddy, I think you are in the wrong section, as judging by how 'stripped out' your car is, that looks like it's a track car. Bet it weighs nothing! Anyway, have you thought about supergluing a £1 coin to the end, almost like a miniature steering wheel. Actually, use a penny as it'll save weight.
  29. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Are you trying to achieve 300bhp with the back seats still in the upright position? If you lie them flat the K07 will easily blow over 308.976whp.
  30. superkarl
    9,423
    2,382
    i really dont think its the rods. my tuner told me that if i get a fmic il have to change them because of the power increase, so ive stalled that mod for a while. but its been running 500ftlbs of torque for a few months now with no issues, i also have a friend with an S3 that uses standard rods and he has around 500hp from his ko3 hybrid, based on his airflow of 200 and the 0.4 rule of course
  31. superkarl
    9,423
    2,382
    my car doesnt have back seats???? my s3 is a 2 seater??? you must be in the wrong section
  32. badger5
    9,424
    1,972
    5 door 2 seater
    hmmm - unusual
  33. superkarl
    9,423
    2,382
    it was £5000 option from the factory bill
  34. mk1chopper
    mk1chopper Missing the S3
    1,092
    Have you removed the floor pan and replaced it with checker plating riveted in place?
  35. damo.h
    damo.h DVLA Say it's Black
    3,610
    67
    I'll just say...... Pure gold!!! ;)
  36. Solly
    927
    you would pay full gold for a car with a weird engine and a 8mm antiroll bar made of bamboo with BIC pen springs, a 1p steering wheel to save waight and no springs?
    if so i have one for sale
  37. Ryan_W
    Ryan_W Member
    336
    If you're looking for speed, you need to carbon wrap various internal components. The wrap will reduce weight by a good 100kg. That corroborated with 173psi in the front tyres will see you over 200mph no worries!
  38. Reesy
    3,640
    148
    I always thought the irony of carbon wrapping is that it actually adds weight to the car - obviously I was wrong!
  39. superkarl
    9,423
    2,382
    great advise ryan, thankyou.
    i run 200psi in my tyres, is it safe to reduce to 173??
  40. Solly
    927
    same, just googled it and found... Carbon wrap = mc2 * 0.52g = (-KG)
