Serious help needed!! oil in coolant 2.0 tdi bkd.. Please
kdotman Feb 16, 2011
  1. kdotman
    kdotman Member
    41
    the cars a 2.0 tdi bkd with 89k miles
    I looked at the coolant today and realised it had lots of oil in it
    I then checked the oil which was just on the minimum line. I topped this up and got home.
    I changed the oil cooler yesterday and flushed the system until it was clear then again today
    I drove today after clearing it and its all gloopy again in the expansion tank
    Could this be the residue or what else
    please help
  2. mike foster
    3,967
    Cylinder head gasket (hopefully) !
  3. kdotman
    kdotman Member
    41
    So is it definately not the residue because it got quick thick again after its changed?
    How much is the head gasket with labour etc
  4. mike foster
    3,967
    Nothing cheap on Audi's mate - don't really know but I would guess at £200 +
  5. kdotman
    kdotman Member
    41
    Damn i was thinking it was the oil cooler.
    Its changed but still bringing oil gunge in the expansion tank
    Could it be residue?
  6. Lewbo
    Lewbo Well-Known Member
    1,269
    106
    A friend of mine had this problem on his car before, he changed the oil cooler and new expansion tank as it had mucky water stained on it and the car is still fine today but the water is a little murky but head deffo hasn't gone, so maybe residue from somewhere
  7. mike foster
    3,967
    Listen mate - it could be lots of things. At that age the cylinder head could be a problem.
    Take it to an independent VAG specialist and get them to scan it for faults and then advise you.
    It's impossible for anyone to diagnose without seeing the vehicle and there are so many possibilities that you need to take it to the experts.
    Sorry !
  8. kdotman
    kdotman Member
    41
    Yeah i know sigh
    I have vagcom with no errors and have revision b cylinder head if that helps
    I just would have thought i would have seen other symptoms from a head gasket or cracked head
  9. mike foster
    3,967
    Rev B cylinder head certainly helps - mine is the same and no probs at 75k ! (touchwood).
    Bite the bullet and take it in mate !
    Good luck :icon_thumright:
  10. kdotman
    kdotman Member
    41
    will do thanks mate
  11. mike foster
    3,967
    Good man - please let us know the outcome for the benefit of others.
    Hope it's good news :beerchug:
  12. kdotman
    kdotman Member
    41
    Good news guys..
    To anyone who has oil in coolant and no other symptoms, CHANGE YOUR OIL COOLER FIRST
    Drove for a few hours today after flushing a few times and no oil has come back
    Hope this helps anyone else with 2.0 bkd engine
