Sensor for Steering Angle (G85): Intermitant Fault
Discussion in 'A4/A4 cabriolet/S4 forum(B6 chassis)' started by ickleric, May 3, 2008.
  1. ickleric
    ickleric Member
    Dec 27, 2007
    91
    My engine management light has come on again, with this error (again). Last time i had it the ESP light was on permanent, but after taking the car for a drive it cleared itself. This time though the ESP light isn't on. When i do a VAG-COM i get this error. Any ideas?? Also what exactly does this sensor do, will it cause any problems if i continue to drive it, will it cause any damage?
    Sensor for Steering Angle (G85): Supply Voltage Terminal 30 - intermittant
  2. Advert Guest Advertisement
  3. Isoproturon
    Isoproturon Member
    Apr 30, 2006
    112
    Got this on one of our A4s when we put a new battery in. Needed to recalibrate the steering wheel, do a search on the net to see how.
  4. ickleric
    ickleric Member
    Dec 27, 2007
    91
    oh right, do you think that could happen if you disconnect then reconnect the battery? as i did to clear another fault i had fixed.
  5. Nickynibbles
    Nickynibbles Damn it where's 7th gear when you need it?!
    Jun 5, 2007
    845
    Its unlikely to show up just by disconnecting the battery. The steering angle sensor is a ring behind the steering wheel that tells the the ecu which way your steering as part of the traction control system. This is why your ESP light was one, it also means your traction control either wont be active at all or not functioning properly. The rosstech website tells how to recalibrate the sensor, but you'll need a registered copy of vagcom to do this. If this dosent fix the prblem they're a doddle to replace, you simply remove the steering wheel & the steering angle sensor is just clipped on to the steering column behind it, no idea of cost mind you!
  6. Stan 24v
    Stan 24v Member
    Jul 13, 2007
    124
    The code may just still be lingering from when the light came on previously, did you clear it down and recheck it?
  7. Isoproturon
    Isoproturon Member
    Apr 30, 2006
    112
    Sorry, but Nickynibbles is wrong, it is very common for it to come on when disconnecting the battery.
  8. jase0851
    jase0851 Member
    Oct 8, 2004
    784
    the esp light does come on when youve disconnected the battery, but it goes out after a couple of hundred metres of driving
  9. Nickynibbles
    Jun 5, 2007
    845
    Exactly, should of been clearer i suppose but this is what I meant! I took my steering wheel off a good few times & disconnected the battery as a result. If I ever got the esp light up it would disappear straight away with no code clearing needed with vagcom as soon as I drove it.
