security access codes needed
tdi-man Mar 2, 2011
  1. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    can any body help need to get in to 01 engine security access 16 but not sure of the access code ?
  2. NHN
    29,647
    1,798
    What do you need to access, is it for cruise cause it does popup what the code is.
  3. tdi-man
    1,783
    64
    engine 01 use to be 12233 but got a new cable and that dont work..
  4. Dana @ Ross-Tech
    Dana @ Ross-Tech Member
    12233 is a common Login for the older (non PD or CR) Tdi engines for certain adaptation channel access. What are you attempting to do, and to what car? Please post the Auto-Scan if you need additional info about a specific procedure.
  5. tdi-man
    1,783
    64
    Trying to get into engine 01 ecu on a 140 tdi bid engine code bit keeps kicking 12233 out ?
  6. Paul1993
    Paul1993 New Member
    Hi guys. Got audi a6 57 reg. 2.0 TDI changed dpf and now having problem with getting a security access code for coding. Anybody can help with this? Got vcds but its not throwing code for me. Also got foxwell 80GT which one asking for same code, any ideas? Thanks
