Secondry air pump
Andie0 Jun 13, 2013
  1. Andie0
    Andie0 Member
    490
    13
    Hi all, can i delete this and if so what do i take out and is there anything i needto buy in order to do this properly?
  2. Paul @ Unit 9 Remaps
    Paul @ Unit 9 Remaps Site Sponsor Site Sponsor
    2,035
    131
    Need mapping out once done can pull it out, basically it's just for omissions for the cat
  3. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,132
    its used when you first start the car up and the car runs rich extra air is blown through the system to try and dilute the gases
    delete it and remove it by all means but in the long run it will shorten the life of your cat
  4. Paul @ Unit 9 Remaps
    2,035
    131
    As above couldn't be bothered to right it all, worth doing if you going decat :)
  5. _adam_
    _adam_ Member
    47
    This was something i was looking just to simplify the engine bay more than anything, is there a blanking kit of a guide anyone knows of ?
  6. madmike01uk
    madmike01uk Member
    430
    21
    you can fit a resistor to stop the CEL. I did the delete on my old car as the SAI was noisy. All it does is blow warm air onto the cat to try and lower emissions, I cannot see how it can shorten the life of the cat at all, unless by cat you mean the neighbours moggie who is breathing in the emissions, then yes it will shorten the cats life.
  7. Andie0
    Andie0 Member
    490
    13
    I have no cat now anyway! I have a revo map will they be able to adjust the ecu to suit if i take it back there
  8. Paul @ Unit 9 Remaps
    2,035
    131
    No as there are a generic map you need a custom one
  9. dualmono21
    1,132
    if you have no cat now then fine , but in your sig you list a 200 cell race cat ,
    if you did the mod and removed the secondary air pump while still having this installed over time when starting the car
    the cat would become saturated due to the excess emmisions
  10. kwistof
    kwistof South East Events Moderator Regional Rep
    2,434
    534
  11. Andie0
    Andie0 Member
    490
    13
    Havent updated sig soz, i had a 200 cell on there but gutted it and rewelded it back together to work as a decat! I am very happy with my map and didnt realise there would have to be a custom map done after deleting secondry so i think i will just leave it as car is tip top and reliable as it is! Thanks for your advice people
