seat back
banny May 3, 2007
  1. banny
    banny Member
    The plastic backing of my drivers seat has come away, (sport seat) is there anyway of repairing it.
    Thanks for any help.
  2. banny
    banny Member
    is there a repair kit for this, have seen on an American site there is, but no pics.
  3. banny
    banny Member
    Right there is a repair, I have ordered it from Audi for just over nine quid, so does anyone know how to remove the back of the seat on the top part, is there a tool you use to get them out.
  4. tommyt2
    tommyt2 Member
    97
    The top of the seat is held in with 3 clips metal ones, they wont break but they are glued to the backing your removing, which is made of cardboard so be careful.The easiest way to remove this part is by prying out the two side as high as your able and then use a screw driver in the middle at the top of the seat try to be quick and pull and you should pop the cover off easily hope this helps:icon_thumright:
  5. banny
    banny Member
    I will try this, would be handy to be able to get it off.
    it just looks untidy with the back hanging off
  6. JGrant1285
    JGrant1285 Sir Scouser Benitez
    225
    Ive got exactly the same issue at the moment. DO you have any part numbers for this kit? HAve you done it and is it striaght forward?
  7. banny
    banny Member
    Yep, can help you there, its pretty easy to do, just get a screwdriver in the top part and release the 3 clips, then slide up, the new metal clips push into existing broken one, then slide in. to refit slide the seat back down into clips them clip in top.
    Part number is 8E0898035 METAL RETAINER
    price £10.66
    Hope this helps
  8. JGrant1285
    225
    my clips that have broken are the plastic clips towards the bottom on the seat-back....are these included in the kit? Do you know which ones i mean?
  9. banny
    banny Member
    You get metal clips that push inside the existing plastic ones
  10. JGrant1285
    225
    good stuff.....i'll get onto Audi...thanks for that
  11. banny
    banny Member
    no problem
