Seat airbag worry, undoing one of the seat runners
T8DPR May 17, 2013
  1. T8DPR
    T8DPR If Carlsberg Made Audi Drivers...
    820
    151
    43
    I managed to drop something down the side of my seat, it made its way through the smallest gap in the carpet underneath the seat runner
    I need to basically undo the seat runner just to give me enough room to get a finger or two into the gap in the carpet, I know its always wise to disconnect the airbag, but is it a faff disconnecting cables and the battery terminal and having to reset it all again, OR will I actually be able to do this without disconnecting anything, and without setting off the airbag, obviousy?
    any help is appreciated!!
  2. NHN
    29,577
    1,779
    Disconnect battery, unbolt 4 spline bolts, unclip airbag etc looms & away you go, then in reverse.
  3. JRock247
    JRock247 Well-Known Member VCDS Map User
    801
    482
    Takes about 10 -15mins to complete, real easy job!
  4. T8DPR
    820
    151
    43
    so if I was to leave it all connected up I definitely run the risk of deploying the airbag no matter how careful I am with the seat runner?
    its only one side I need to get at you see
  5. NHN
    29,577
    1,779
    Just follow the advice given, its your easiest/best option.
  6. T8DPR
    820
    151
    43
    on reconnecting the battery, do certain things need resetting?
  7. NHN
    29,577
    1,779
    Just drive up the road & cluster lights should distinguish, windows may decide to need auto close/open resetting, but should be fine.
  8. T8DPR
    820
    151
    43
    no problem, will the stereo need its code re-entering?
  9. NHN
    29,577
    1,779
    No.
  10. Cozza McA
    Cozza McA Crunching The Gears VCDS Map User
    410
    74
    Take the advice from NHN! He knows his stuff.
    I took both my seats out with battery still connected then moved the car, looks like I missed a bullet haha
