Seat airbag plug help (pic)
fUbAr8p Oct 13, 2010
  1. fUbAr8p
    fUbAr8p Member
    35
    Hi guys
    Had to take my passenger front seat out at the weekend to fix the runners... meaning I had to unplug the airbag from underneath. The problem I have is, there are 2 plugs looking exactly the same and only 1 socket. I remember only 1 of these was plugged in but I can't remember which one!
    Can anyone tell me which plug needs plugging in? I have heated seats in the 2004 TDi if that makes a difference.
    Thanks.
  2. PH1L
    PH1L Gievf Buckets
    3,851
    40
    id go with the one thats taped in with that loom already plugged in
  3. fUbAr8p
    fUbAr8p Member
    35
    That was my reasoning... however I would like to know for sure?
  4. 347
    347 Active Member VCDS Map User
    354
    47
    it could just be photo , but both plugs you show look different .
    the one taped into the loom looks like the right shape to fit socket ?
    is this the case ?
    car manufacturers normally make plugs different so the wrong one cant be inserted into wrong socket
  5. fUbAr8p
    fUbAr8p Member
    35
    It's the photo. Both plugs are identical, just with different colour wires going to them.
    If someone could pop out in the cold and check theirs for me, I'll give them a biscuit.
  6. ryanstewart9
    ryanstewart9 Member
    494
    Can you not see the colour of the cables in the plug attached to the car?
    Just thinking they may be the same as one of the plugs in the seat?
  7. PH1L
    PH1L Gievf Buckets
    3,851
    40
    do both looms in question goto he seat, and are the seats factory spec
  8. fUbAr8p
    fUbAr8p Member
    35
    Yes both looms go into the factory leather seat. Any ideas?
  9. phil76
    phil76 Active Member
    572
    40
    Does one have two wires and the other 3 or is it a bad picture? can you not look at the other side if thats the case?
  10. fUbAr8p
    fUbAr8p Member
    35
    They both have 3 wires.
    Problem solved though. I plugged the one on the main loom in and drove to a specialist to get the airbag light cleared. They couldn't do it, as the fault was shown as 'static'. So swapped them over and the light cleared.
    So, for reference the airbag loom for the passenger seat is the plug on it's own at the top of the pic. No idea what the other one does, maybe for a power seat?
  11. PH1L
    PH1L Gievf Buckets
    3,851
    40
    mine has 2 sets but ones for the power adjusters odd that you dont have the extra port for it
