Sealey code reader
a3emma Feb 7, 2010
  1. a3emma
    a3emma Member
    43
    don't no if ive posted this in the right section or not.
    i bought a sealey code reader from work recently. when i plug it im my car it says there was a error with linking it uptomy car.so i checked the fuse and it had blown, so ive changed the fuse,and it still comes up with the error on the code reader. now a year ago or so, i got the codes read with my dads mates reader, and it worked fine.
    i know its not the code reader itself as it works fine on everybody else car, so its just mine it dont like!
    does any one know what could be up with it, or experianced same problems?
    thanks
  2. Mpathe
    Mpathe 1st gear
    394
    do you have the std radio in or do you have an aftermarket 1 fitted
  3. a3emma
    a3emma Member
    43
    ive got a after market one in.
  4. Mpathe
    Mpathe 1st gear
    394
    take the radio out and unplug it, then try the code reader again making sure the fuse is ok.
  5. a3emma
    a3emma Member
    43
    just been out to try it and still no joy, the last time it got code read when it worked there was a aftermarket headunit in it, but a different one to what ive got now.
    anymore suggestions?
  6. Mpathe
    Mpathe 1st gear
    394
    think the best thing now is to try vag-com or vas on it and see if they work. it might be that your reader isnt compatible with your car or that the ecu it connects to might be faulty. theres a sticky thread somewhere that tells you who and where people live who can cannect it to there computer if you need help
  7. a3emma
    a3emma Member
    43
    ok thanks for your help!
