SDS Question
BILKO1 Nov 26, 2009
  1. BILKO1
    BILKO1 Member
    301
    I've just finished installing my fbmfsw and bluetooth and did the sds hack while i was at it. All is working fine after a few technical hitches:) and some help from forum members. Is there a full list of sds commands floating around? Should phone numers be displayed in the dis? and how do you delete a radio station voice tag that is wrong?
  2. NHN
    29,298
    1,701
    Press PTT button say help & it will list most commands.
    If you press Mode on the wheel it changes the DIS from phone list to radio etc iirc unless coded wrong.
    Voice tag, urrrm thought it was by 2 methods, delete all tags through rns sds menus or through sds itself, cant recall tbh as did ages ago.
  3. BILKO1
    BILKO1 Member
    301
    I know about the help commands but there isn't a command to delete a single entry or all in the radio voice tags, you can in the directory menu for phone numbers etc. I thought the mode button only worked on phone kits not bluetooth. I'll do a vcds scan and post it up so you can see the coding.
  4. NHN
    29,298
    1,701
    Strange cause I remember deleting a radio station, need to go check again.
    Mode works with rns which lists the BT connected phone phonebook if coded for rns high iirc.
  5. BILKO1
    BILKO1 Member
    301
    Here's the log
    Friday,27,November,2009,11:46:45:63169
    VCDS Version: Release 908.1
    Data version: 20091018
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8E23A187741 Mileage: 159710km/99239miles
    Address 01: Engine Labels: 038-906-019-AVF.lbl
    Part No: 038 906 019 JT
    Component: 1,9l R4 EDC G000SG 1572
    Coding: 00003
    Shop #: WSC 63351
    WAUZZZ8E23A187741 AUZ6Z0B0173883
    No fault code found.
    Readiness: 0 0 X X X
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517 A
    Component: ABS/ESP allrad 1726
    Coding: 04255
    Shop #: WSC 06435
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 K
    Component: A4 Klimaautomat 1016
    Coding: 00000
    Shop #: WSC 63351
    2 Faults Found:
    01842 - Potentiometer/Actuator for Temperature Flap; Right (G221)
    30-10 - Open or Short to Plus - Intermittent
    00716 - Air recirculation Flap Positioning Motor (V113)
    41-10 - Blocked or No Voltage - Intermittent
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 E
    Component: int. Lastmodul RDW 0305
    Coding: 00001
    Shop #: WSC 63351
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 B
    Component: Airbag 8.4EP 2000
    Coding: 0010602
    Shop #: WSC 63351 000 00000
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 R
    Component: Lenksáulenmodul 0801
    Coding: 04042
    Shop #: WSC 06435
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 981
    Component: KOMBI+WEGFAHRS. RB4 D35
    Coding: 01401
    Shop #: WSC 00001
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8E0 035 192 Q HW: 8E0 035 192 Q
    Component: RNS-E HIGH EU H74 0660
    Revision: 04S Serial number: AUZBZ7G0052604
    Coding: 0301715
    Shop #: WSC 32727 551 00000
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0604
    Coding: 00001
    Shop #: WSC 00000
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 BC
    Component: Komfortgerát T3B 1110
    Coding: 07115
    Shop #: WSC 63351
    Part No: 8E2959802B
    Component: Tõrsteuer.FS BRM 0002
    Part No: 8E2959801B
    Component: Tõrsteuer.BF BRM 0002
    Part No: 8E0959801A
    Component: Tõrsteuer.HL BRM 0002
    Part No: 8E0959802A
    Component: Tõrsteuer.HR BRM 0002
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0301715
    Address 76: Park Assist Labels: 8Z0-919-283.lbl
    Part No: 8Z0 919 283 A
    Component: Parkingsyst. A4 RDW D07
    Coding: 00114
    Shop #: WSC 63351
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P0 862 335 S HW: 8P0 862 335 S
    Component: FSE_256x BT H34 0550
    Revision: 00000000 Serial number: 00000005087273
    Coding: 0011802
    Shop #: WSC 00000 000 00000
    End ---------------------------------------------------------------------
    Heater controls throw up various codes now and then but always clear and the heater / aircon works fine.
  6. BILKO1
    BILKO1 Member
    301
    I've sussed the radio station delete option. You have to say "read list" the when the station you want to delete is spoken you have to press ptt button and say "delete". Just got to sort this mode / dis now.
  7. vanbling
    vanbling New Member
    One to remember.
  8. BahnStormer77
    BahnStormer77 BahnStormer
    2,757
    54
    There is a bug on early DIS screens: when left clicking the scroll wheel for numbers, the phone number pops up for a second or so, but then disappears FAST.... not sure if it was sorted by 2002, definitely all good on some of the 2003's.
