SD card issue - format ?
ColinS Nov 12, 2011
  1. ColinS
    ColinS New Member
    25
    Hi
    I have a 59 plate S3 with RNS-E headunit fitted.
    The issue I have is it will not play certain files stored on my SD card. All files are mp3 format but only some of them appear on the list of stored of files on the card.
    I have tried formatting the card and putting only one file on it which it has previously not recognised. An error message saying unknown files appears and it will not play.
    I am puzzled because some of the files work and some dont ?
    Is there a certain type of mp3 file these will not recognise?
    Any help would be greatly appreciated !
    the SD card is a sandisk SDHC 32gb.
  2. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,486
    1 - is card formatted correctly FAT 32
    2 - are files over 320mbps?
    3 - are files being copied from Windows or Mac ( if Mac may be worth trying BlueHarvest software)
    4 - if files are burned to cd-r will they work
  3. ColinS
    ColinS New Member
    25
    Thanks for the reply.
    Card is formatted to FAT32. The files play on cd-r in the 6 disc changer. Files are being copied from windows 7.
    Only thing I am unsure is if they are over 320 mbps ? How would I find out ? I take it this is a requirement for them to play ?
  4. ColinS
    ColinS New Member
    25
    I have just checked the properties of one of the files that wont play and it states the bit rate being 320 kbps ? is this what you mean ?
  5. ColinS
    ColinS New Member
    25
    I have just checked one of the files which does work and the bit rate is 220 kbps. Now even more confused !
  6. Paul100
    Paul100 Member
    111
    am having exactly the same problem, seems to be no connection between bitrate or file size??? just doesnt seem to like some files??
  7. ColinS
    ColinS New Member
    25
    Yeah. Really frustrating ! . . . All files are mp3 format so really cant understand it !
  8. Paul100
    Paul100 Member
    111
    was chatting with a techy guy at work and he said it may be a dodgy sd card (faulty sectors or something). Have another one with different tunes on that works fine so will try to find somewhere that sell non HC SD cards to try the same songs on a different card....
  9. 5ean
    5ean S3 Owner VCDS Map User
    415
    So the problem is HC cards? Just bought one last night and tried it and it just says 'Reading card' and never changes..
  10. ColinS
    ColinS New Member
    25
    Paul100 - Let us know if you have any joy with the non HC sd card.
    I knew the older RNS-E head units didnt like HCSD cards but I thought it was a case of they would play everything or nothing at all. Not selected tracks.
    Colin
  11. Paul100
    Paul100 Member
    111
    Well found a non hc card transferred the same files over and............................. nope! still the same. Cant figure it out....
  12. 5ean
    415
    Does anyone have a 4GB card they can confirm works? What make/model is it?
  13. jonny87
    jonny87 Active Member
    1,094
    a bit of a late reply but i was told to only use 2gb sd cards, anything bigger and it doesnt like it!
    not tried mine yet (still trying to get the satnav to work) but its just a thought for you :)
  14. Paul100
    Paul100 Member
    111
    only using 2gb cards.
    I have shortened the artist names and track titles and it seems to have worked. Not had time to look at the details yet though..
  15. jonny87
    1,094
    seems a bit of a faff to me, wouldnt it be easier to install an aux input or mp3 dock in the car?
