scuttle panel
r3stu Jun 13, 2010
  1. r3stu
    r3stu Member
    111
    Does the front scuttle panel need to be removed for the fitment off coilovers? If so how is it removed? Cheers
  2. PH1L
    PH1L Gievf Buckets
    3,851
    40
    yes, sharp tugs does the job
  3. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,486
    632
    No it doesn't - I have managed several times between S/A3's to change the whole front suspension without taking the scuttle panel off.
    It's easy enough and saves you having to remove the wipers as well.
  4. PH1L
    PH1L Gievf Buckets
    3,851
    40
    what about the 3 bolts that are located under it?
  5. Boydie
    3,486
    632
    Easily reached with a 13mm inch long socket and small ratchet spanner and finish off removal with your hands.
    It is easier of course to remove the scuttle panel but this saves time IMO!
  6. PH1L
    PH1L Gievf Buckets
    3,851
    40
    haha i would imagine its a ****** to fit the new ones, never thought f going throught the honeycomb
  7. Boydie
    3,486
    632
    I don't go through the honeycomb mate. I lift the front of the scuttle panel up at the front and there is enough room to get your hand and ratchet in to remove the 3 top mount bolts.
  8. PH1L
    PH1L Gievf Buckets
    3,851
    40
    ahh got you now mate wee bit of a irritating job getting the coils in on the three bolts?
  9. Boydie
    3,486
    632
    It is not too bad - you can easily get the front or side one in to locate the top mount and then finger tighten the back one to line it all up once in position. Then tighten them all up with a small ratchet!
    As stated, it is easier to remove the wipers and panel but it is possible to do it without!
  10. NHN
    29,550
    1,777
    TBH I've done the lift scuttle up route many times, but it is a damn site easier to remove wipers which is a 3 minute job at most & remove panel as its only clipped in, 5-10 mins job at most, then do the job at hand & refit, cause you can easily snap the plastic panel lifting it up tbh & squeezing your hand & socket/spanner in there is a pita, when you can easily remove the offending parts til job done.
    Why I didnt do this before is beyond me I tell yer, I only realised 2 weeks back the poxy panel was clipped in place & lifted out so easy, was unreal.
  11. PH1L
    PH1L Gievf Buckets
    3,851
    40
    yeah its tough to get it to come out to begine with but after youve gotten it started its easy as pie :)
