Scuff on rear bumper
Caesium Mar 13, 2007
  1. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    had a close encounter with a very small concrete bollard today and its scuffed my rear bumper, any tips on how to repair it? its gone through the paint and into the material of the bumper, so ideally I suppose i'd need to rub the area down and filler it then re-spray?
  2. TDI
    TDI Member
    296
    someone like chipsAway?
  3. marmite
    marmite Counting the Tesco Club points
    1,101
    Where are you based?
  4. AndyMac
    9,832
    46
    I had a similar issue with my bumper. Not worth going to a bodyshop but significant enough to spoil the car. I just rubbed it down very carefully keeping tight to the scratches, tiny amount of filler and then masked it off really tight to the offending area, and with each coat moved the masking away from the area slightly so as to minimise the new/old paint join.
    Then used alot of Tcut to erradicate the overspray. Then used the same technique with the lacquer. It's the lacquer coat that makes all the difference as this is the glossy coat that needs to blend as it will catch the light. It was a real bodgey technique (I'm no pro on paint jobs) but worked really well and saved me a couple of hundred quid for 2 hours work and was surprisingly satisfying.
  5. Caesium
    4,879
    I live in kent but work in Ware, Herts. Why's that?
  6. silver75
    silver75 Big Ron
    3,265
    he wants to burgle your house
  7. Caesium
    4,879
    ROFL!
  8. smitch
    smitch Active Member
    1,588
    Fit a lot in the back of an RS6..........
  9. Caesium
    4,879
    Can you get a 42" plasma in an RS6 then?
  10. smitch
    1,588
    I'd ask Marmite but he's out on a blag. :ninja:
  11. silver75
    silver75 Big Ron
    3,265
    as.net brag of the year?
  12. HOUCH
    HOUCH Member
    89
    The get away will be quite rapid too.
  13. TDI
    TDI Member
    296
    What have you heard about them? have you used them? i'm worried now as i am in the process of using them.:think:
  14. silver75
    silver75 Big Ron
    3,265
    depends mate some are good some are bad
  15. petewon
    petewon Member
    529
    Just to add to this, Ive done the same thing a little while back but it scuffed the top of my bumper and the lower bumper which is the grey bit on the A4. Anyone know how I would get a paint match for the grey lower bits on the A4?
    Cheers :)
