Screw sheared in halve... Pic! Help!! Lol.
Paddymph Aug 28, 2012
  1. Paddymph
    Paddymph Member
    70
    So. I had thermostat issues. Changed it last week and fixed it, all was well! Cool! Noted that I was loosing about a cupful of water a day, it was dripping from
    The housing, culprit bein me using An old gasket (yes i know). Anyway, I go to fix tonight and this happens:
    So it's sheared off leaving the screw still in there. Will the garage be able to remove this You reckon? It's in a right tricky area :(
  2. aragorn
    18,544
    865
    If you remove the plastic housing can you get a grip of the bolt shank?
    If not you'll need to drill it and use a stud extractor.
  3. brasiliangringo
    brasiliangringo Member
    626
    10
    It sheared because you over tightened it the hex bolt or am i not seeing this clearly ... ?
    You could always weld another bolt onto the end of the shank if there is access.
  4. Paddymph
    Paddymph Member
    70
    Yea I think over tightened mate. :(
    I've left it for tonight in case anyone can think of any bright ideas In here. I may just let the garage do it.. Reckon they'll be able to get a drill in there?
  5. aragorn
    18,544
    865
    You might not need a drill, Now its snapped it wont have any tension on it, so if you can get a grip on it it'll just wind out.
  6. Paddymph
    Paddymph Member
    70
    Yea i thought that halve went into metal but it goes into plastic thermostat housing doesn't it.
  7. aragorn
    18,544
    865
    The thermostat housing is aluminium? Only the elbow is plastic...
    Take the plastic housing off and see if you can grip onto the remains of the snapped stud.
  8. Paddymph
    Paddymph Member
    70
    Ok will try that. And then B and Q for another screw, they should stock something similar I hope.
  9. Paddymph
    Paddymph Member
    70
    Also. Is that large hex bolt (bottom left of pic) a drain plug for the coolant?
    Thanks for everyone's help so far :)
  10. aragorn
    18,544
    865
    Yeh thats a coolant drain.
    B&Q should have a suitable machine screw. I think its an M6.
  11. BA4
    BA4 Member
    76
    If you can't grip with anything use a flat head and try loosen it by tappin it anti clockwise, it's not so bad as you sheered it tighten it as f this happened when loosing it you'd have no chance, although I think the bolt is a unusual side as I tried getting one myself
