Screw holding disc to hub
dusty Mar 20, 2012
  1. dusty
    dusty Active Member Team Nogaro Blue Audi S3
    267
    46
    Hi, does anyone know what size countersunk screw I need to buy, to replace the screws that hold the discs to the hubs, as both of the rear screws are snapped in the hubs.
  2. Jacko4130
    Jacko4130 Goodie Gum Drops
    848
    I'm sure there M6 thread
  3. <tuffty/>
    21,874
    4,201
    Most motor factors or Halfrauds should sell them tbh
  4. dusty
    267
    46
    Generally are they all the same size for different makes of cars
  5. Darren4
    Darren4 Member
    186
    Try b&q as you they have many differant sizes
  6. The Doctor
    The Doctor Well-Known Member
    1,394
    189
    Do you need to replace them? Surely once the discs are correctly located on the hub, then the wheel bolts hold them in position? Isn't the screw just there to hold the disc in position while the wheel is off the hub?
  7. StaceyS3
    StaceyS3 Well-Known Member
    2,505
    502
    I replace mine with Allen countersunk ones although still have a tendency to round off as m6 only use a 4mm Allen key but you can still put more torque through it than a Phillips or pozi drive screw ;)
  8. dusty
    267
    46
    I haven't over tightened the screws, I replaced the rear pads a few weeks ago and noticed both the heads of the screws were missing sheared off, and yes I am aware the screws are only to locate the disc on the hub, I just wanted to know the thread size and then I can source some from work
  9. L33h
    L33h Member
    215
    Exactly. I havnt got any in my car. Just need a bit of skill to put the wheels on haha
  10. StaceyS3
    2,505
    502
    Sorry I meant torque to get it off not tighten up ;)
