screen wash smell
jpda4 Jan 14, 2014
  1. jpda4
    jpda4 Member
    127
    21
    Hi all, looking for advice..... help....
    for the last few days whenever use the screen wash getting a rotten egg smell coming into the cabin.
    always use screen wash fluid and fresh water, not always measure as per instruction, think the last top up was close to 50/50 mix
    for now its not to bad but want to catch this before it gets worse
    looking for suggestions on easiest way to flush the system through and what to use...
    dont think emptying a full reservoir using the pump would be a good idea to flush through
    would putting the hose pipe in the tank and letting it run for 15 min be enough
    thanks in advance
    forgot to mention its a 61 plate 2.0 tdi a4
  2. Rodders.
    Rodders. Active Member
    183
    I've dumped whole tanks using the pump before
    Halfords do some scented stuff, its pretty strong, chuck some of that in there?
    Dunno if you can put bleach or anything in to help kill of the bacteria?
  3. Anthony566
    Anthony566 Active Member
    732
    111
    43
    I had this with my last A4 and I just put clear water through for two full washer bottle loads then filled with neat Audi screen wash for a week and then reduced it to a 50/50 mix for a while and this sorted it ... But it did stink really bad and I can only assume I had mixed to makes of screen wash that didn't mix well and created some bacteria in the water.
  4. jpda4
    jpda4 Member
    127
    21
    thanks chaps,
    think the cause might have been something black on the filter, deceased/drown fly/spider....
    removed filter and put hose pipe in left it run for a while, part emptied using the pump and added neat additive smell for now has all gone.....
    still in searching for the bottle though, guess its hidden between the inner wing and wheel arch liner
    going to run this to empty then put some good stuff measured to the correct ratio
  5. SJC
    SJC Active Member
    187
    44
    Interesting post. I have this smell normally when the car had been heating up for a short while whilst driving. Never put it down to screen wash though. Have been thinking it's the car and cat. Had it since May and it's done 17,500 so due it's 2at service soon. It's a 2.0tdi engine. But never had this smell with any other derv cars and have had 5 now over the past few years due to the millage I do.
  6. SI-W85
    SI-W85 Well-Known Member
    1,321
    351
    Try using Milton steriliser through it then water for a tank, should be good after that :)
    scotty76 likes this.
  7. jaygemson
    jaygemson Active Member
    154
    91
    This ^^^
    I had this problem all the time with my mk2 Focus RS, minging. Dissolve a sterlising tablet (e.g. Milton, or Boot's own etc) and chuck that in the washer bottle. When you next come back to the car the smell's gone.
  8. SJC
    SJC Active Member
    187
    44
    Thanks for replies.
    I used the search function and i think this is the most realistic answer. As no fault codes are displayed on the dash and you would not expect problems with a cat after only 8 months.
