Screen wash level sensor
Rhodesy Dec 26, 2013
  1. Rhodesy
    Rhodesy New Member
    24
    Should our B7 have a sensor for the screen wash level? Ran out today with no warning.
  2. Arnie013
    Arnie013 Member
    152
    13
    Don't quote me on this but I think so yes. Every audi I have ever been in has had one apart from my uncles old 80.
  3. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,138
    definately one on the b6
    connection is behind the passenger side front wheel underneath the wheel arch liner
  4. SinghB7
    SinghB7 Active Member
    534
    69
    Mine is the same, when it is low it dosn't give me a warning.
  5. rizzini7
    rizzini7 Active Member VCDS Map User
    983
    156
    43
    Mine doesn't, assume it depends if it came with full DIS from the factory
  6. Rhodesy
    Rhodesy New Member
    24
    Hmmm thanks guys. I would have expected it to have one tbh but perhaps not then? The car has some form of DIS but not the full thing maybe as it only provides basic stuff.
    Think I will have a look behind the wheel arch and will let you know if I find anything.
  7. kite
    kite Member VCDS Map User
    677
    Press the check button and see if the washer warning comes up. It looks like a spouting whale....
  8. Rhodesy
    Rhodesy New Member
    24
    No, doesn't come up mate. Just coolant, oil and brakes I think. Can it be easily enabled if the sensor is retro-fitted?
  9. Paranoid69
    Paranoid69 Member
    79
    Yup needs to have the full DIS. If you do the retrofit of the DIS upgrade you have a choice, install the sensor into the washer bottle and run a wire back to the back of the dash, or don't do the sensor and just ground a pin on the back of the dash (and do without the warning).
  10. Paranoid69
    Paranoid69 Member
    79
    Apart from that the DIS retrofit is a stalk and VCDS to change some settings, usually done at the same time as adding cruise (as it needs a stalk change too)
  11. Rhodesy
    Rhodesy New Member
    24
    Well I topped up the screen wash today and found a wire going to a grommet on the top of the washer bottle. Would this be for the level sensor as I can't imagine what else it is for?
  12. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    I think you might be referring to the overflow pipe here...
  13. Rhodesy
    Rhodesy New Member
    24
    You could b right there bud 😄
    Never seen a washer bottle with an overflow before?
  14. rizzini7
    983
    156
    43
    The sensor goes in the place of a bung near the bottom of the bottle afaik
  15. NHN
    29,596
    1,782
    No not all cars have the sensor, it was never a default factory fitted item.
  16. dentsy
    dentsy Loving my new to me allroad
    770
    53
    Hi, fitted my dis and now got FULL computer functions :)
    just got that damn washer fluid low warning :-(
