Screen keeps going off on sat nav/ radio system
Jakes3 Jan 21, 2014
  1. Jakes3
    Jakes3 New Member
    I've got a rnse sat nav/ audio unit that's got a fault ....the screen keeps going black but the radio still works fine ....can anyone recommend anyone to fix this for me ?
  2. AJC
    AJC 3rd Gear
    180
    23
    Have the same problem Jakes3........It's most likely the ribbon that's at fault which will either be loose or slightly damaged at the end....you can either cut the damaged ends off and reconnect or try some flexible silver circuit board paint from Maplins for around £10
  3. Anthony566
    Anthony566 Active Member
    732
    111
    43
    Has this unit had its DVD drive replaced ? If it has the screen ribbon may have moved, I have replaced the drives in a few of these and it's easy to check the ribbon.
  4. AJC
    AJC 3rd Gear
    180
    23
    Anthony566 - Can you explain how to gain access to the ribbon? Any user guides available for the DIY enthusiast?
  5. AJC
    AJC 3rd Gear
    180
    23
    Jakes3 - have just fixed my own unit with this problem, happy to fix yours or talk you through it if needed
  6. Anthony566
    732
    111
    43
    Hi sorry I didn't reply I completely forgot ... pm me an email address and ill send you a document I have with instructions and photos.
