Screeching noise
physk Mar 10, 2011
  1. physk
    physk Member
    34
    Got an Audi a4 1.9tdi
    makes a sharp grumbling noise when you full lock the steering wheel either way
    any ideas budds?
  2. swarcup
    swarcup Well-Known Member
    1,326
    40
    Check your power steering fluie level, they do this when its below level. Best place to start
  3. kujo
    kujo New Member
    17
    If not it could be the alternator pulley! I had this recently and mine had seized. The garage replaced this and the belt and I think it was about £180 as they had to take the alternator out to replace the pulley due to a lack of space in the engine bay.
  4. chrisash32
    chrisash32 Member
    573
    Exacaly the same as me. After a while mine got worse and was even doing under normal steering.. So i had it replaced yesterday :)
    Replaced the alternator pulley and also the AUX Belt + AUX Belt Tensioner.
    All working fine again now :)
  5. mattyboyc
    mattyboyc B6 Veteran Audi A4 Audi Avant Owner Group TDi
    1,999
    218
    I've had the same on mine,it also squealed when you backed off the throttle that turned out to be the air-con pump bearing had seazed.
