scangauge 2 wont detect boost on my s3 8l
s3evil34 Feb 5, 2018
  1. s3evil34
    s3evil34 Member
    84
    Hi just a quick one been using my friends Scangauge 2 on my s3 .Plugs into the obd picks up everything just not my boost ? but works fine on my friends r53 jcw mini . could my map sensor be playing up ? anyone use these things ?
  2. <tuffty/>
    22,048
    4,311
    if your MAP sensor is foobar then you would know about it...
    Never used that particular tool myself...
  3. s3evil34
    s3evil34 Member
    84
    It's american just found some info on it it measures manifold pressure from the map sensor But because the map sensor is on the intercooler pipe work i dont think it will work on the 8l.it does say in small print wont work on some vehicles. So that's that then lol
  4. <tuffty/>
    22,048
    4,311
    It won't read vacuum is all... boost is boost... its a pressure sensor
  5. s3evil34
    s3evil34 Member
    84
    Yeah i can always fit a boost gauge next to it if i want. But i mainly want the scanner just to monitor inlet temps. Plus it does loads of other things like mpg. Data logs. 0.60 timing etc Bit of a toy so why not.
  6. Stuart B
    Stuart B Well-Known Member
    2,268
    419
    I don't trust the boost gauge on android torque pro. It's a little bit sketchy
  7. <tuffty/>
    22,048
    4,311
    If its reading from the MAP sensor its seeing what the ECU is seeing... only reads to 22psi anyway and reports as absolute pressure
  8. Stuart B
    2,268
    419
    don't know... the stable readings might be good (I am not usually watching) but if you leave it on real time readings you get a max of say 36psi - I think the Android Torque Pro - Track Logger Plugin is more accurate.
  9. <tuffty/>
    22,048
    4,311
    lot of lag over the bluetooth dongles and k-line is not fast especially when you are tracking a few PIDs
  10. s3evil34
    s3evil34 Member
    84
    Android torque pro . Will check that out Thanks
  11. Stuart B
    2,268
    419
    you get a bluetooth device from ebay and you need to buy the full android app as the free app doesn't include the boost pressure. overall cost about £6
  12. s3evil34
    s3evil34 Member
    84
    Bargin! Dont suppose you have a link for the bluetooth device ?
  13. Stuart B
    2,268
    419
    eBay android torque bluetooth
  14. Siondc
    Siondc Learner!! Ming Blue S3 AMK
    86
    9
    Any similar devices available for iOS?
  15. Stuart B
    2,268
    419
