Scan Gauge / Liquid Gauge.. Can it display the Post I/C temp ??
JonBoi25 Aug 28, 2011
  1. JonBoi25
    JonBoi25 Member
    236
    Hi people,
    as above really was looking at getting a gauge to see if a recent mod brings down the Post I/C temp at all. Any info on whether these gauges will display this ? If not any recommendations?
    Cheers, Jon
  2. MUSH
    MUSH MUSH Developments Ltd.
    713
    12
    Yep it shows air intake temp which is measured from the ait sensor in the inlet manifold
  3. <tuffty/>
    21,576
    4,048
    Liquid reads the IAT's in the same way as the ECU/VCDS etc... uses the sensor input from the inlet masni so it will give you IAT's as the ECU sees them...
    Not sure on the other stuff as have not used them but suspect they work the same way..
  4. JonBoi25
    JonBoi25 Member
    236
    ah i see great stuff should work fine then , could someone show me where the AIT sensor is exactly ?
  5. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    It wont and cant read the temp before the intercoolers
  6. JonBoi25
    JonBoi25 Member
    236
    Thanks s3Dave for your comment, but i was questioning Post I/C which will be after the intercoolers, I just wondered where the AIT sensor was in the manifold ?
    Many thanks
  7. <tuffty/>
    21,576
    4,048
    Its next to the throttle body....
