Saving a white 3.0 quattro build thread.
Super Ron May 28, 2014
  1. Welshquattro
    Welshquattro Active Member Team Mauritius quattro Audi A4 Audi Avant Owner Group
    783
    143
    43
    That's just what I need , my passenger side airbag light is above the radio and I wanted to move it. Just hope now I have the wiring in the overhead light. Do you have the part number for the overhead light?
  2. Super Ron
    Super Ron Active Member
    459
    202
    43
    if i have to take it out again i'll get it for you :cool:
  3. Super Ron
    459
    202
    43
    so a bit more today :)
    started off debumpering the audi
    rears are a bit of a pain as you have to take out all the rear interior, sub and and box etc.
    started on the rear, the blue upper had some bad reversing dents so i checked the upper bumpers part numbers and they were the same so swapped over
    i had wondered if the rear Sline lowers were deeper than the SE or it was just the addition of the vent. it turns out they are deeper
    SE exhaust cutout
    and the bottom brackets are flat on the SE and stepped on the Sline
    fitted it on the car to check tow bar clearences :shrug:
    so out came the powerfile and a bit of zipping, try cut try cut try cut cut try
    much better than the square chop they made when fitting the tow bar
    Then on to the front
    i followed this as a guide
    DIY: B6 A4 - Ultrasport Lower Front Bumper with Stock Upper
    and got chopping
    alot more trying and cutting and back and forth, i had a bit of a problem that my upper was infact origionally off the silver one all those posts ago as i wanted headlight washers, and had been in a bit of a knock and split all the underneith, above the foglights, and glued and screwed back together etc, so not quite right. it never really fitted spot on, but you never noticed as it was all white lol. So this hampered fitting the Sline lower as its all a bit crocked. but got it all on
    the only bit that doesnt line up spot on due to the damage is this leg, but still acceptable and wont notice when its all on. you can also see a few descete screws i had to put in the grilles as the inner bit they normally clip into arent there.
    and all done
    will be going off to my mate the painter tomorrow :)
    sumo and Andy_w like this.
  4. sumo
    sumo Active Member
    217
    47
    You my friend have way too much spare time!
    Epic thread though.
  5. ruffrida
    ruffrida Well-Known Member
    1,926
    313
    Tgats goin look awesome. Brilliant thread
  6. Greeny233
    Greeny233 It's all about the V8. Team V8 Team Silver Audi S4 Audi Avant Owner Group
    1,094
    385
    Do you have any idea what I would have done to get that back bumper in that colour? I looked for 3 years then had to go with a battered red bumper.
    I think it would have been easier to fit the entire front bumper rather than modding your original one.
  7. Super Ron
    459
    202
    43
    I'd be the same looking for a white rear! I bet two will turn up at once now.... Two reasons I didnt use the blue front bumper, 1. It didnt have headlight washers, and 2. Sline upper and lowers complete go for good money :)
    Greeny233 likes this.
  8. Chrismawa
    Chrismawa Active Member
    457
    46
    Great thread mate, and nice work!
  9. Chrismawa
    457
    46
    I've got the same on mine, annoying rattle over bumps in the road. Did yours stop when the brakes were applied?
  10. ruffrida
    1,926
    313
    This is a proper common problem, it is the retaining clip on the caliper, proper annoying, i need to replace mine as i have bent them that far that thy now touch me wheel inner hub, they are the crapest idea in the world, a ten min fix takes all that annoying rattle away !!
    Greeny233 and Andy_w like this.
  11. Chrismawa
    457
    46
    Is that the big long clip on the front of the caliper? Whats the fix, just replace them?
  12. Mike.M
    Mike.M Well-Known Member
    2,510
    170
    Yes just replace. You can bend them out for a period of time but they just get weaker......at the bending stage myself LOL
  13. Chrismawa
    457
    46
    Haha ok thanks! Least I know what it is now, was driving me mental lol
  14. ruffrida
    1,926
    313
    Yep,only solution is to replace. Like it's been said they can be bent but only so far
    Chrismawa likes this.
  15. Chrismawa
    457
    46
    OK cheers mate. Sorry for the thread hijack! :ninja:
  16. ruffrida
    1,926
    313
    Tell me bout it, wont let me mrs have passenger window down, as only the NS is bent to far lol
  17. Greeny233
    1,094
    385
    ive had thisd annoying rattle for ages, ill give some new clips a go.
  18. Super Ron
    459
    202
    43
    I carried on felting the bumpers untill I was happy with them. Done a few repairs
    primed and prepped up and loaded in the wagon to take to my old work for a mate to whiten them up
    That was yesterday, and picked them up this morning :)
    You can see it alot clearer the SE upper and Sline lower chopping now its in white. I did find that the bit I cut out of the se lower at the bottom does in fact clip in the tabs on the sline lower to allow the fog light grilles to clip into
    Here is a rear shot I forgot to put up before painting
    The origional silver engine donor a4 had an undertray and spats I took off all those years ago as my white one never had one, so thought it would be a good idea to fit them....... but now I cant find all those 90degree twist bolts they use so will have to get some more :(
    I managed to get the wonky leg to line up better with the grilles too
    And here we are all done!
    All ready for a trip to Santa Pod in the morning :)
  19. barkclark
    barkclark Active Member
    960
    174
    43
    Awesome mate!
  20. sumo
    sumo Active Member
    217
    47
    Ron that looks stunning mate,am so jealous of the build just wish I had more money and time!
    Three A4s later you got there!
  21. JJWin
    JJWin Member
    37
    13
    Think I've just spent about an hour reading through all that! Amazing work and great effort in putting so much work in to your car, it looks awesome. :icon_thumright:
  22. Greeny233
    1,094
    385
    Looks fantastic all you need to finish it off is the boot spoiler. Great Job.
  23. ruffrida
    1,926
    313
    Wow,a quality job,very nice
  24. Super Ron
    459
    202
    43
    Had a great day at santa pod. Its about 100 miles each way and the audi seems to have wiped out a complete spices of bugs by the look of it!
  25. Greeny233
    1,094
    385
    Mine looks like that but they are stone chips :eek:(
  26. Super Ron
    459
    202
    43
    Just to show its not all show queen now and still gets used, I had to go and pick up some bikes so got to show how the non sline tow bar fits with the sline bumper,...... very well
    also gave the 'new' mower a workout ;)
    sumo likes this.
  27. Chrismawa
    457
    46
    So its the clips that are rattling not the pads? Do i just bend them towards me?
  28. Mike.M
    2,510
    170
    Yes and no.
    The retaining springs/clips push the caliper back and prevent it from knocking the top of the outer pad.......but theses get weak over time and the caliper gets enough play to hit the top of the metal backing of the pad to creat the knock noise......and I am too at the point of replacing them now.
    About £10 for the pair and apparently should be replaced with every brake pad change but think mine are original and coming up to ten year old now, so had their day LOL
  29. Chrismawa
    457
    46
    Ok thanks, are these available from Audi only? Dont suppose you have a part number?
  30. Mike.M
    2,510
    170
    Most probably getting mine from ECP for £9 something and are made by Pagid. Waiting on my mate at TPS to get me a price for genuine ones before I commit there but.
    No part numbers unfortunately mate.
  31. Chrismawa
    457
    46
    OK no problem mate, post any info up if you get any.
    </end thread hijack> :yes:
  32. ruffrida
    1,926
    313
    £11 from unipart dude
  33. sumo
    sumo Active Member
    217
    47
    # Loving the lawn!
    Cobra88 and ruffrida like this.
  34. Super Ron
    459
    202
    43
    I had one job i wanted to do as i knew i had a few free hours this weekend.
    As said in a previous post I'd had these kicking around from the original silver donor but the clips were buggered so never bothered
    it wasnt the under tray that bothered me so much but the little corner spats you can see in the wheel arch always looked unfinished
    So got a bag of ebay clips to hand
    Got it up in the air with an empty undercarriage
    And on
    And more importantly got the little spats on :)
    I will probably be swearing about the bloody thing every time i need to do something on the car now, but its on :)
    In other news id been doing a bit of research into load rates etc for shocks and found what sport shocks would be fitted to a 2002 3.0 quattro avant and found the part number needed, followed by ebay old new stock searching found this for £35.
    Just need to find another now :)
  35. Jimmy TDI
    Jimmy TDI Pro Tinkerer Audi A4 Audi Avant Owner Group TDi
    1,320
    262
    I was lucky enough to come across a seller with a pair of matching front shocks when I was looking for mine. I just need to find a set of rears now so I can refresh all of the back end arms and bushes too.
  36. antowens
    antowens Car Nut Regional Rep
    845
    275
    I take my hat of to you mate this thread is awesome would love to be able to do something like this one day messing around with cars is just me to a tee keep up the good work fella
    Car is looking great and should be massively proud of it the work that's gone in to it is just unreal
    O and the lawnmower is fantastic hahaha
  37. RSKperformance
    RSKperformance Member
    52
    9
    Hats off to you! This is love!:)
    Very detailed thread. Can you confirm how low is it now/was it from se suspension. Iam about to get adjustable coilovers so deciding how low ...
    Thank you in advance!
  38. AudiS3-Turbo
    AudiS3-Turbo Member
    619
    27
    Great stuff, not scared of work I see ;)
  39. Super Ron
    459
    202
    43
    cheers everyone, i was hoping to find someone with a few shocks in stock but no such luck. the search continues....
    i am happy with how it all looks and sits now :) the only problem now is i am a bit bored of the performance after 2years :( but it is just a family hack afterall :)
    suspension wise im not sure how it compares to the standard SE but from the centre of the wheels to top of the arch is about 31.5cm front and rear now its all settled.
  40. AudiS3-Turbo
    AudiS3-Turbo Member
    619
    27
    throw the 3.0 away and do as i did .... 2.7t :D
