Sat nav plus system not working please help.
daveturbo Mar 1, 2012
  1. daveturbo
    daveturbo Member
    72
    I bought a 58 plate audi s3 last night with 13,000 miles. The system will not connect using the bluetooth, also when trying to load a SD card this does not work. I tried to load a cd in the slot last night and again this does not seem to work, (there is a disk spinning around in the system) and on the flip down display it says there is a dvd already in there, but for some reason when i click the eject button nothing happens. I would be most gratefull If anyone can shed any light on these problems which i seem to be facing.
    Thanks Dave.
  2. Paullie
    Paullie Banana Menace! VCDS Map User
    2,076
    288
    Hi Dave, when you say it won't load the SD card, do you mean it's not going into the SD card slot or that it goes in but won't play the tracks? In the 58 plate cars, the RNS-E is the MK1, which will only play non SDHC cards of no more than 2GB in capacity. Also they must be in FAT32 format. The Sat Nav disc is actually locked into the CD drive and IIRC it can only be unlocked using VCDS. Enjoy your new S3! :wub: xx
  3. daveturbo
    daveturbo Member
    72
    It goes in tries to read but cant load anything. I thought it could be somthing to do with the lock from factory. But what about the bluetooth? Also it has the ipod docking station and this seems to work fine, thanks for the reply,
    Dave.
  4. Paullie
    2,076
    288
    Not sure why your BT isn't connecting, Dave, sorry :(. Hopefully one of the guys will be able to shed some light on this for you in a bit. :wub: xx
  5. daveturbo
    daveturbo Member
    72
    Thanks for the help paullie, the SD card now works :) one prblem fixed
    Dave.
  6. daveturbo
    daveturbo Member
    72
    Does anyone else know any more advice for me?
    Dave.
  7. kite
    kite Member VCDS Map User
    677
    The DVD drive can be unlocked by a dealer or with vagcom. Are you sure bluetooth is fitted?
  8. daveturbo
    daveturbo Member
    72
    Im not too sure how do you mean by fitted, is there something extra that is required for it to work? Is there a way to tell, i mean the screen says telephone not installed, and when i try to pair nothing happens it cant even find the unit on my phone.
    Thanks, Dave.
  9. kite
    677
    If your phone is not discovering the car when searching you may not have bluetooth fitted
  10. Paullie
    2,076
    288
    Yeah Dave, as Kite says, you may not have BT fitted. It is not something that is incorporated into the RNS-E unit. It is a separate unit that is connected up to the RNS-E. Did the dealer say that the car came with BT? :wub: xx
  11. kite
    677
    you could call Audi CS on 0800699888, give them the reg No. they can tell you what was fitted at the factory
  12. daveturbo
    daveturbo Member
    72
    Thanks again for the reply, i bought the car private so im not to sure. when i rang the dealership they couldnt tell me the orignal cars spec. If it doesnt have the bluetooth on the system is it hard to install and what would the expense involved be?
    Thanks dave x
  13. daveturbo
    daveturbo Member
    72
    Thanks for the number mate, i will give them a call now and see what the spec from factory was.
    Dave.
  14. daveturbo
    daveturbo Member
    72
    GUTTED, just spoke to them they said the car was not standard with the blue tooth :( i really wanted that to work aswel, is there any way of geting this working without changing the entire unit?
    Dave.
  15. s8craig
    1,750
    55
    Yes it can be added quite easily, either OEM or 3rd party.
  16. daveturbo
    daveturbo Member
    72
    Ah that's good then, I would rather keep it all OEM working through the original unit, ad make it all work properly, can you give me any more information on this please. Thanks, dave
  17. daveturbo
    daveturbo Member
    72
    Bump
  18. Paullie
    2,076
    288
    Hi Dave, depending on where you live, you may be able to get a member to fit OEM bluetooth for you. NHN (Nigel) fits these OEM BT units as well as lots of other things. Might be worth PM'ing him for a quote.
    You need something like this, which comes with all the required looms etc -
    eBay - The UK's Online Marketplace
    :wub: xx
  19. daveturbo
    daveturbo Member
    72
    Ok, thanks again I will look into it more this week :)
    Dave
  20. Paullie
    2,076
    288
    You're very welcome :wub: xx
  21. daveturbo
    daveturbo Member
    72
  22. Paullie
    2,076
    288
    Hi Dave, it looks like the correct BT module for your car. I think N8 is also selling a BT module at the moment. You will also need the correct loom to connect it all up and it will require coding via VCDS. :wub: xx
  23. s8craig
    1,750
    55
    That module is not for your car, it's an 8T0 module for A4/A5/Q5
  24. daveturbo
    daveturbo Member
    72
    Will it still work, i heard a few people say that the modules are all the same?
    Dave.
  25. s8craig
    1,750
    55
    I have been doing installs of genuine BT for over 7 years, I can say it will not work. If Audi used the same part then it would have the same part number.
    I also know as I carry both parts and I put an 8T0 into an A3 by mistake and it didn't work. You need an 8P0 or 8P1 part number.
  26. daveturbo
    daveturbo Member
    72
    ok no problem, even if i coded it in on vag com? if not can you help me to get it sorted?
  27. Nokesy
    Nokesy Member
    41
    I too have had the same problem, I have an RNS-e in my 2006, but no bluetooth, so looking to buy one now, any info from this thread would be greatly recieved. First thing i checked for was the mic, as that was missing, gutted!!
    cheers
  28. ben.w93
    ben.w93 Member
    213
    22
    I retrofitted a BT module to my RNS E the other day. It was relatively easy to do, hardest part was removing the RNS E unit, easier with two sets of hands as there are four keys needed to remove the unit. Depending on the car the mic would be in the interior light cluster from what I can gather.
