Sat Nav+ max SD Card Size?
A3_3.2_S-Line Aug 17, 2006
  1. A3_3.2_S-Line
    A3_3.2_S-Line Member
    160
    Hi All,
    Getting my car in a couple of weeks, need get some sd cards for the mp3's!
    Does anyone know if there is a max file size card the sat nav can read?
    I ask as you can now get 4GB cards!!! :hubbahubba:
  2. Macduff
    Macduff Member
    742
    I'm sure that I read 512MB somewhere. Someone more knowledgeble will be along shortly . . .
  3. A3_3.2_S-Line
    160
    Oh I so hope you are wronge:sign_unfair:
  4. simonwjones
    simonwjones Member
    365
    Im pretty sure that 2gb cards work fine in the RNSE, but you must use decent makes, Sandisk etc
    Simon
  5. shark_90
    shark_90 Member
    96
    I currently have a 1Gb and a 512Mb in mine and they work fine. I have also been told that 2Gb work perfectly, but you should stick to quality brands as suggested.
    I've heard 4Gb work, but for the cost, you're better off buying 2 x 2Gb.
  6. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    I use 2 4GB SD cards and 1 2GB SD card.
    The RNS-E has a limit of 512 files plus folders on each SD card, so unless you use a high bit rate (I use 320kbps) you will reach the limit of the number of files before the card is full. I get over 30 CDs per 4 GB SD card, so I have the equivalent of 75 CDs on 3 SD cards.
    Some, mainly older, RNS-E were VERY fussy about the SD cards they would work with - I've tried both normal and high-speed cards. My first RNS-E (HW version 047) would only work with high-speed cards, but my current one (HW version 070) is happy with just about anything.
  7. A3_3.2_S-Line
    160
    Everyone thank you very much! :applaus:
    I'm off to buy 2 x 4GB cards then!
