Sat Nav installation service
imported_craigyjp Jun 9, 2005
  1. Hi, I'm offering a supply and installation service of RNS-E DVD based sat nav systems for A3, A4, A6 and D2 chasis A8/S8 cars. I carry stock of HU's, TV tuners and all the bits to fit them to standard double din cars. I will not be offering facia ugrades.
    Standard installation including 12 months warranty is £1000 and that will include the latest 2005 DVD, all wiring for CD changer/telephone and BOSE where applicable. VAG coding included for your car to match tyres, etc.
    TV upgrades areavailable for existing TV installs when upgrading to RNS-E at a reasonable cost.
    Upgrade your CD based sat nav to DVD based, older pre 2002 cars can be done, but with a few caveats regarding DIS and clusters.
    PM me for details.
  2. cclarke184
    cclarke184 Member
    79
    Interesting post, i was trying to find out installing one of these in my 2001 facelift S3, i take it that it is possible to to this in my car, do you know it there is a model that just slots in or will i need to chop about with face plate of the satnav.
    regards
    Chris
  3. Chris, I read your earlier post with interest and whilst I have an A3 unit here, I think that the A6 unit is more suited to the pre 2002 cars. Yes it will need to be cut down, but it has the analogue speed pulse input required for non can bus vehicles.
    As you need to generate illum etc on the can bus for the RNS-E to work correctly,on non can bus cars this can be done with an add on unit, but pushes up the price another £100 or so.
    You may be lucky and have can bus on your car, if so then installation is simpler still. My S8 is a 2002 model and has a mixture of the 2 canbus and analogue. So I can pick up the signals from either.
    Craig
  4. cclarke184
    cclarke184 Member
    79
    Cheers Craig, how do i find out if my car has the can bus or not?
  5. cclarke184
    cclarke184 Member
    79
    yes, i have a digi clock/date and what i believe to be the facelift model with a single screen on the climate control module.
  6. You may be in luck then.
    Craig
  7. wmd10
    wmd10 Member
    43
    what are the plus points of the dvd version over the older cd one?
  8. Mcgough
    Mcgough Member
    846
    im upgrading, cheers to craigyb!!
  9. Cupramax
    Cupramax Uber pimp meister
    457
    Hi,
    I'm interested in getting an RNS-E fitted to my Sportback. It currently has the Symphony II/Bose HU so i take it its just a plug in jobby? Craig have you got stock at the moment?
    thanks
  10. Cupramax
    457
    Nice one, thanks for the info.
  11. Mcgough
    Mcgough Member
    846
    How do i operate the Split screen mode map/directions option, and the
    3D overviews option, i just get a normal display all the time!!
  12. Karcsi
    Karcsi Member
    426
    Just had a search around. It's just an optional adapter which works with the RNS-E. 385 smackers for the A3!! Are they mad?
    According to Craig, posting on Tyresmoke earlier this month, the Parrot CK3300 is compatible and is about one 8th of the cost.
  13. Here are a couple that I've done this week....
    S8 RNS-E & TV upgrade (in motion mod)
    A4 RNS-E upgrade from D to E
  14. I'm based in the NW of England.
    Craig
  15. dreddg
    dreddg Member
    81
    Hi Craig
    Quick question, already have satnav + in my 98 A6 but looking at adding the TMC unit, as a friend had one in his nissan and really helped in a major accident and diverted us around it, How much do you charge ? /ubbthreads/images/graemlins/crazy.gif
    Many thanks
    George
  16. Yep, just got myself 2x RNS-E tuners
    Craig
  17. cclarke184
    cclarke184 Member
    79
    Craig, how do you go about cutting the RNS-E to fit the A3/S3, i'm about to fit the RNS-E in my S3,
    I've got a dremel. Do you cut it free hand or have you a template?
    Chris
  18. A hacksaw and patience my friend. Undercut and then smooth down to fit.
  19. Insert a piece of gloss black trim there like tiling trim or similar. The closest match tou can get to the dash. You can darken up the RNS-E to match using a KIWI magic polish sponge. the RNS-E absorbs the black, but the white of the buttons does not.
    Craig
  20. cclarke184
    cclarke184 Member
    79
    Do you have any pics of A3/S3 that you've done Craig?
  21. What RNS-E do you have, I'm guessing you bought an A6 one as this work well in older cars.
    I don't have any pictures of the A3 I did, it was a while back now before I started doing installs as a service to others.
    Craig
  22. cclarke184
    cclarke184 Member
    79
    Yes, A6 indeed
  23. The911SC
    The911SC Active Member
    1,032
    Craig, What version of Vag Com do you have to set these up?.
  24. The proper version, HEX-CAN vag com lead with 5.04 software.
    Craig
  25. The911SC
    1,032
    Hi Craig,
    PM me with the price of supply only a4 unit inc. kufatec.
    Also a 'c' tuner
  26. dazzatdisport
    dazzatdisport Member
    44
    Hi Craig
    Could you give me the price for a new A3 which already has the double din symphony unit.
  27. You both have PM
  28. dreddg
    dreddg Member
    81
    Craig
    Do you do TMC units?? /ubbthreads/images/graemlins/goofy.gif
  29. You mean fit them or supply them? I haven't supplied one to anyone yet, but I've fitted a oouple.
    Craig
  30. dreddg
    dreddg Member
    81
    [ QUOTE ]
    Craig
    [/ QUOTE ]
    Hi Craig
    sorry should have made myself clearer, do you supply and fit???
    If so how much are we looking at?? /ubbthreads/images/graemlins/goofy.gif
  31. Yes I supply and fit, for your car, you already have an RNS-D installed yes?
    Would the TMC be of any use to you except for the TMC nav section,you have no canbus in that car so the DIS display will not work.
    Craig
  32. rickquattro
    rickquattro Member
    589
    Craig, you have a pm re a sat nav installation.
  33. dreddg
    dreddg Member
    81
    [ QUOTE ]
    Craig
    [/ QUOTE ]
    I have satnav + F version ( i think?? if not G)
    All I am after is the TMC to give me alternative route due to road problems/ traffic
    How much am I looking at? and where do you fit?
    George
  34. TMC units are around 150 to 200 euros with all the cables, but I need to clarify your nav system before we can say ye it will work.
    Maybe you can send some pics of your nav to my email addres or post on here, NAV comes in 4 types as far as I'm aware.
    BNS - DIS only, controls by hand brake
    RNS-C early model double din unit
    RND-D later model double dinunit DX
    RNS-E DVD based latest model
    Which one do you think you have?
  35. dreddg
    dreddg Member
    81
    [ QUOTE ]
    [/ QUOTE ]
    From what I believe it is an RND-D, as it is CD based and i think it was taken from a 2001 audi. Hope this helps????
    George /ubbthreads/images/graemlins/goofy.gif
  36. This is an additional Phatnose install I did on my mates S4
  37. rickquattro
    rickquattro Member
    589
    pictures are hooj Craig.....and that address in Wehr, hope my lass's folks don't get too many visitors...
  38. I know, I resized them to 6x5 but they still seem to be big
    Craig
  39. The Slug
    The Slug Active Member
    1,869
    How would i get around the fact that i have the climate panel above a gap/flip panel, cause mine is just the single din stereo CD player, like this, i know its not the best of angles but let me know what can be done please.
  40. You need a double din conversion to be done. Not the cheapest option on an A3, but can be done.
    Once this has been achieved you can fit in an RNS-E
    Craig
