Samco T.I.P. - Where to find good quality hose clips ?
darko Dec 12, 2005
  1. darko
    darko Member
    272
    I finally did the decent thing and purchased a Samco turbo intake pipe (in nice oem black) and am now looking for some nice clips to fit it. I did have book marked a link but I seem to have lost it. Im looking for the proper quality clips for either end of the pipe rather than use the 'orrible jubilee style clips. Anyone know where I can find them ?
  2. Ess_Three
    Ess_Three Active Member
    5,383
    14
    Jubilee clips are fine..there's no pressure so they are no problem
    If you want stainless clamps, Demon Tweeks sell a variety of them...I think Mikanor do jubilee type as well as some others suitable for the low pressure hoses - you can't fit big beefy wide clamps as there's no room!
  3. darko
    darko Member
    272
    thanks - ill check demon out, just dont like the way jubilee clips vut into hoses..
  4. jojo
    28,856
    3,516
    Didn't you get no clamps with the TIP?
  5. RichA3Turbo
    5,089
    My local 'The Motorist Centre' do some heavy duty jubilee clips...Can do tehm up really tight and they are nice and wide so dont cut in.
    Rich
  6. darko
    darko Member
    272
    the only clips i got with the tip were the smaller jubilee ones - the main ends have no clips, the pipe was an unused one from ebay so maybe they do come with all clips new ?
  7. darko
    darko Member
    272
  8. darko
    darko Member
    272
    and for a description of all clamp types here:
    http://www.teconnex.com/products/clamps_couplings.htm
    seems ring clamps (t bolt) are recommended for turbo applications..
    i like the fact they have a nylock nut so wont come loose and the continuous inner band design doesnt cut into the rubber or silicon pipe
    more info / recommendations on the old vortex forum..
  9. PaulRS3
    PaulRS3 Well-Known Member
    1,211
    143
    JCS Marine Grade stainless Steel ones.
    Nice and shiny, bit wider than standard Jubilees, and you can give them grief.
    They havent budged since i fitted them
  10. darko
    darko Member
    272
    thanks Paul - was looking for someone who had fitted some. Where did you get yours from ?
  11. Grant
    Grant Well-Known Member VCDS Map User Audi RS3
    1,206
    118
  12. darko
    darko Member
    272
    those are the ones, anyone know the sizes required for all the boost pipes ? i might oredr a job lot and replace the standard ones whilst im fitting the tip this weekend
  13. god_thats_quick
    2,507
    not sure on the sizes, but if you got the TIP then a ruler and the demon tweeks website should sort your problem.
  14. darko
    darko Member
    272
    i have the tip sizes covered (60mm & 90mm) but was wondering if anyone knew what the intercooler pipes are etc as i might just replace the whole lot while my hands are getting dirty !
  15. god_thats_quick
    2,507
    ah, I'll get back in my box then!
    Good luck and if you find out make sure it gets posted on here for the rest of us that may be doing this in the not too distant future!
  16. darko
    darko Member
    272
    will do - ill try to get some pix too !
  17. PaulRS3
    1,211
    143
    [ QUOTE ]
    [/ QUOTE ]
    got mine through an engineering supplier at work.
    http://www.wak-tt.com/mods/hoseclips/hoseclips.htm
    has a link to where you can get them online.
