  1. adrian2006uk
    adrian2006uk Member
    139
    looking at getting some samco hoses as concerns about the standard pipes collapsing
    how many pipes do i need to change and the best place to get them from
  2. s3ollie
    s3ollie Member
    762
    changing the intake pipe will cure colllapsing as this is the vacume side of the system so 1 pipe there. but there are more by the intercoolers you can change too but this is a + pressure side so wont collapes.:icon_thumright:
  3. CycleSi
    CycleSi Member
    Which hose is the one you are talking about? Where is the "intake pipe"?
    Is it the one on the drivers side at the front of the engine?
  4. sitrials
    sitrials Member
    872
    looking at the very cool picture below:
    the Hose thats going from your airbox(top right) to the turbo is the one that can collapse under suction as i have seen in a video or 2.
    the other hose route as so...
    hard pipe (round the engine) to the rubber hose (front left) goto the front left intercooler and then a connection to a hardpipe (bottom of the engine bay) to the other intercooler then another hose (bottom right) that leads to your inlet manifold.
    these can expand under high boost pressures but are more than sufficent for a standard S3.
    Hope that helps!
  5. sitrials
    sitrials Member
    872
    best place ive seen is forge!:icon_thumright:
    they show them all with fitting guides!
  6. CycleSi
    CycleSi Member
    Just so l am absolutely sure you are talking about the same problem:
    The "intake pipe/hose" likely to collapse, (especially when a Revo remap is fitted), is the one at the back of the engine, closest to the bulkhead next to the Diverter valve where it says "5V Turbo"?
    I'll get it eventually.....
  7. sitrials
    sitrials Member
    872
    YES
    get the uprated samco silicon hose from forge that'll solve it.
  8. Prawn
    11,510
    3,425
    surely Samco make the samco one Si? and the Forge one is made by Forge?
  9. adrian2006uk
    adrian2006uk Member
    139
    hello just to make sure i order the correct pipe as only need to change one that might collapse is this the correct pipe
  10. sitrials
    sitrials Member
    872
    they are all the same
    yes thats the hose
  11. CycleSi
    CycleSi Member
    Does anyone know the Samco product code for this hose?
    Is it TB1007?
  12. dultanur
    dultanur all promises, no action :)
    407
    i've been running the std. hose for quite a while now and have had no problems...
    but the samcos do look cool :icon_thumright:
    and BTW, thats the right code.oh, and they only fit the cars that have ESP...
  13. ChriS3
    ChriS3 hud at ye bam
    2,239
    27
    A collapsing hose is not as common a thing as its made out to be. Silicone TIPs are generally little more than a cosmetic thing. Dropping a metal sleeve down the existing top will do just as good a job.
  14. CycleSi
    CycleSi Member
    So you don't think it is worth replacing that hose?
    Since I've had my S3 Revo re-mapped, l have a little "fluttering" when accelerating hard in 3rd gear - not a hesitation or misfire though. I've had a new MAF fitted and that hasn't helped. l'm going to replace the spark plugs with new NGK's but several people have said to look at replacing that hose.
    Although it is difficult to describe how it feels, it could easily be a hose momentarily collapsing and then 'regaining' its shape.
    There seems to be so many owners out there suffering a similar issue but no-one seems to know for sure what causes it. Most people say replace the MAF and that will cure it but it hasn't !
    Is there some kind of checklist that I (and others) can go through by process of elimination until it's sorted?
    What exactly is VAG.com and how does it work?
  15. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,155
    1,987
    I haven't replaced my MAF and have no samco or new dv and all I experiance is the air being sucked in at volumes when booting it but I'll check the third gear thing tomorrow
  16. HTC
    HTC Active Member
    3,428
    9
    if you are going to replace pipes. Do the small ones for the DV an n75 that run from the large main metal turbo outlet pipe. seen 2 s3's fail here due to excessive heat.
    Also y shaped breather hose on cam cover seems to be weak spot.
  17. AwesomeSarah
    AwesomeSarah Member
    726
    Hi
    Yes Samco do Samco and Forge do SilliconHoses.com
    Both do the same job , I have heard a few complain about the hoses collapsing on the T.I.P`s
    The 225 ones are different , so be aware when ordering the parts
    We can do the Forge products at below retail too http://www.awesome-gti.co.uk/forgemotorsport.html
    That is our prices
    Sarah
  18. Blunteh
    Blunteh Member
    196
    I assume this sort of thing is best diagnosed on a dyno ?
