Saloon Rear Speaker Removal
tonya4 Dec 6, 2010
  1. tonya4
    tonya4 TDi Powerrrr
    408
    I have got some replacement rear speakers on the way for my saloon,and wondered if I have to remove the whole parcel shelf to change them ,or do the grills pop off?
    I know I need adapters to fit my new speakers.
    thanks
    tony
  2. Broken Byzan
    13,237
    465
    Shelf out job as the grilles are mounted tot he shelf anyway.
    The shelf clips to the edge of the steel along the most forward section with pop in clips, Once popped, it then slides into the cabin off the shelf.
    Lie on you back in the boot and look up, you will see the clips/poppers if you use a torch or similar.
  3. tonya4
    tonya4 TDi Powerrrr
    408
    thanks,i thought that was the case but wanted to be sure,before I break anything
    tony
  4. griswold
    griswold Member
    350
    Dont forget to unplug the brake light wire that will stop it sliding totally off.
    Just done mine last week much better now
  5. tonya4
    tonya4 TDi Powerrrr
    408
    what adapters did you use or did you make your own?
    tony
  6. griswold
    griswold Member
    350
    CT25AU04 Connects 2 Speaker Fitting Adapter for Audi A4 rear Shelf 165mm
    Ebay item 350413877884 6.99 del
    next day del for me
  7. Oranoco
    Oranoco Well-Known Member
    3,818
    357
    I made my own to house a set of Kenwood Dualmag 5.25" speakers. Only there for a bit of rear fill.
  8. tonya4
    tonya4 TDi Powerrrr
    408
    what thickness mdf did you use?
    tony
