Saloon interior into Avant...?
Geeman Oct 31, 2011
  1. Geeman
    Geeman Low Life
    1,318
    I've seen some leather from a saloon that is quite an 'interesting' colour and I was wondering if it would fit into my Avant.
    Of course, the front seats and door cards wouldn't be a problem, but are the rear door cards the same?
    Would the rears require some work to get them to fit?
  2. aragorn
    17,957
    701
    Rear door cards and bench are the same.
    The rear backrests locate the same at the bottom, but the top edge on the saloon has a U shaped clip, and the avant has a Pin.
    That said, early (<97) avants had the same fitting as saloons, so i'd imagine the metalwork is probably still there and you'd just need to graft in the saloon fitting.
  3. Geeman
    Geeman Low Life
    1,318
    Brill... thanks!
  4. olds_kool
    olds_kool Active Member VCDS Map User
    1,089
    13
    Rear saloon door cards don't have speakers unless it's fitted with Bose
  5. aragorn
    17,957
    701
    good point! but the colored bits can probably be transferred over to the avant cards?
