Saggy Door Adjustment
Von Maximo May 27, 2010
  1. Von Maximo
    Von Maximo The Damned
    344
    Hi,
    Anyone know how to adjust the doors as mine have sagged a bit over the years.
    Oh and please no cowboys saying "Stick a jack under door and lift"
    Thanks in advance!
  2. Khufu
    Khufu Well-Known Member
    5,704
    31
    i keep meaning to look into this myself. I reckon the hinges will need shims.
  3. wickyianr1
    wickyianr1 Member
    106
    did mine a couple of months ago you need 2 of you really i just undid the lock what the door shuts to there is quite a bit of play and you can move it in all directions got it all lined up nicely.forgot to mention not the hinge end the other
  4. PH1L
    PH1L Gievf Buckets
    3,851
    40
    it depends on where the sag has occurred tbh more often than no the chrome hinge on the pillar just needs lifting but if not that its a case of adjusting the hinges, that being said most body shops will just do it primitivley though maybe not usng a jack
  5. Khufu
    5,704
    31
    Think I'll bump this thread LOL
    Anybody managed to lift the height of their doors?
  6. Farhan
    Farhan Active Member
    1,234
    57
    Second this kufu! anyone able to shed some light my doors have sat down a little from what i have noticed. I also have creaking sounds from them over rough roads.
    Iv used Krytox (Du Pont) lubricant on the seals it does help but doesnt last long before the noise comes back. Certain its because the doors need realigning and then lubricating.
  7. Ports
    Ports Member
    68
    My driver door has done the same thing. i might have a go this weekend and put some info up if it goes well. lol
