safe mode???????????
deano1978 Mar 3, 2013
  1. deano1978
    deano1978 different gear
    713
    81
    Took my cluster out to clean,full of dust.
    On putting back. Mileage reads fuse then safe and also wont start....arrrrhhhhh.
  2. dpbayly
    dpbayly Member
    391
    I take it you have tried unplugging and plugging back in, in case there's a bad connection?
  3. AndyMac
    9,832
    45
    Need to check fuses sounds like you've blown one
  4. hades-
    9,481
    646
    as above check fuse
    then check its plugged in right.
  5. deano1978
    713
    81
    Im putting hand through the side by fuse box and wriggling. Lights gone on and off if wriggled hard. But keeps coming back on to safe mode where the mileage reads? Not saying fuse no more?
    Turns over but just cuts out?
  6. hades-
    9,481
    646
    take them back out and refit plugs
  7. dpbayly
    dpbayly Member
    391
    Check one of the tiny pins on the back of the cluster haven't bent over and is missing the hole in the plug easily done if not careful
  8. deano1978
    713
    81
    Will do. should also mention that the coil is flashing and handbrake as well as no lights working
  9. deano1978
    713
    81
    No good all looks good. Getting a code 00474
    cluster light up but not properly. As in ngt time
  10. dpbayly
    dpbayly Member
    391
    Did you dismantle the cluster to clean or just remove?
  11. dpbayly
    dpbayly Member
    391
    That codes is
    00474 - Control Module for Immobilizer
    Sounds like its a communication problem with the cluster for sure
  12. deano1978
    713
    81
    Nightmare for sure
    18056 missing drive train comms
    18043 ac fuse
    17978 immobilzer
    18062 colant temp
    All this in aid of abit of dust to clean inside cluster. And followed a how to.
    I dont no where to start :-(
