S8 windscreen
Discussion in 'A8/S8 forum' started by Medders, Dec 10, 2003.
  1. Medders
    Medders Member
    May 31, 2003
    34
    £600 /ubbthreads/images/graemlins/shocked.gif
    My insurance are sorting it, so hopefully I only have the excess to pay !
    Anybody confirm or deny this price ?
    Paul
  2. Advert Guest Advertisement
  3. SvenS8
    SvenS8 Member
    Sep 11, 2003
    78
    That's about right for a heated one, a bit on the high side maybe (€795 here IIRC). If it's not heated it should be less IMO. Prices vary from €500 (£350) - €800 (£560).
    Code for the heated one is 4GM by the way (see sticker in service manual). You sure which type you need yet?
  4. Medders
    Medders Member
    May 31, 2003
    34
    mine isn't heated. I thought it sounded a lot.
    Is there anything I need to look out for when they're changing it over ?
    Paul
  5. Mutley
    Mutley Member
    Jan 3, 2003
    67
    Hi Paul,
    Make sure the correct type of bonding gunge is used. About 4 years ago I had a 98 R S8 and its screen had been replaced by a non-Audi dealership. I could hear constant clicks and creaks from the dash area and eventually I got the screen replaced by Audi. This stopped all the noise which I think was caused either by the wrong bonding gunge (not flexible enough?), or by part of the screen touching the frame.
    As soon as you get it replaced, go for a drive with the heat full on to cause some expansion, and then open up the windows to get the inside really cold. Any clicks or creaks and I would tell them to do it again...
    /ubbthreads/images/graemlins/beerchug.gif
    Jon
  6. Medders
    Medders Member
    May 31, 2003
    34
    Thanks Mutley.
  7. SvenS8
    SvenS8 Member
    Sep 11, 2003
    78
    Oh, and make sure you demand an original screen (with the Audi logo on it), otherwise you may end up with some imitation cr*p... /ubbthreads/images/graemlins/wink.gif
  8. Medders
    Medders Member
    May 31, 2003
    34
    I phoned my garage to check up on their expectations.
    Apparently using a non Audi sourced windscreen can invalidate your warranty (and the stuff they use to bond the windscreen)
    Anyway, they took my car away, and i just got a call to say my screen has a photo reflective coating on to reflect heat in summer ! (never knew you could get this, but I am happy!)
    Paul
