S5 DSG gearbox redline?
Lloydie22 Mar 9, 2014
  1. Lloydie22
    Lloydie22 Member
    62
    9
    Apologise is this is a daft question but i have the audi s5 with the s tronic gearbox. Earlier on i had just given it a wash and wanted to show my brother the sound of the engine when parked up. So i put the car into park and revved the engine. I was supprised that it only rev'd to 4000rpm and wouldnt go higher, i tryed it in neutral aswell and the same outcome.
    Why is this? And is there anyway to redline the car when parked?
    I have googled it but can't find anything,
    Thanks.
  2. Lloydie22
    Lloydie22 Member
    62
    9
    Anybody know about this please? Still cant find any info on the web
  3. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,486
    Think it's an inbuilt safety feature to limit engine damage and risk of over-revving. Seen it on a few Audi's recently.
  4. Lloydie22
    Lloydie22 Member
    62
    9
    Hmmm, so should it rev to the redline when stationary?
  5. warren_S5
    7,210
    2,486
    Not sure off the top of my head, but I suppose the question is would you want to? It's probably not going to do it any favours TBH.
  6. Lloydie22
    Lloydie22 Member
    62
    9
    I would just like to hear the v8 roar at 6000 rmp when its stationary! I'm supprised it doesnt let you. I wouldnt want it to redline when driving but i think it should when stationary!
  7. warren_S5
    7,210
    2,486
    If there wasn't a risk it might damage the engine then Audi wouldn't have set the limit. I suppose the risk is people start the car and start revving the arse off it when it's cold. It may also be linked to launch control system???
  8. Lloydie22
    Lloydie22 Member
    62
    9
    Whats launch control then mate? Sounds like a spaceship!!
  9. warren_S5
    7,210
    2,486
    Actually I've just noted your car is pre-2010 so may not have this.
    1. Turn off traction conrtol (ASR).
    2. Move shifter to D/S or chose Dynamic with your Drive Select
    3. Step on brake hard with left foot for atleast 1 second.
    4. Step on the gas all the way and hold it til the engine rev stop increasing.
    5. Let go of brake within 5 seconds.
    They missed the number 6, but it should be:
    6. Don't **** your pants.
    AdamZA and DAYTONA 500 like this.
  10. Lloydie22
    Lloydie22 Member
    62
    9
    Ah mine doesnt have that. Sounds like a pretty decent feature though!
  11. N4th4n90
    N4th4n90 Member
    52
    10
    As above, some kind of inbuilt safety feature I've seen on a few VAG cars. The Veyron's limit is only 3k when stationary iirc!
  12. Lloydie22
    Lloydie22 Member
    62
    9
    Oh okay, thats abit anoying. But thanks for the info! My old manual s5 used to bounce of the rev limiter stationary. Mind you, that was a 2007
  13. A5sprint
    A5sprint Member
    93
    22
    My 2008 S5 manual will only rev to 3.5k in neutral but with foot on clutch will rev higher
  14. Audi Toby
    Audi Toby 2016 S3 Saloon
    256
    51
    To turn of the 4k limiter (petrol) 2.5k (diesel) you need to simply hold down your ESP button for 6 seconds to disable ESP/TCS, after that you'll be able to rev it whilst at stand still in neutral. Be warned though! Don't damage your engine, it's there for a reason.
    warren_S5 likes this.
  15. Lloydie22
    Lloydie22 Member
    62
    9
    Thanks for that. I have held the ESP button off though and it still only revs to 4k. Any other ideas mate?
  16. Bustamoves
    Bustamoves Flat Foot Shifting
    186
    13
    R35 gtr is the same when stationary
  17. Audi Toby
    256
    51
    What year S5 and transmission have you got?
  18. Lloydie22
    Lloydie22 Member
    62
    9
    2009 S5 tip tronic
  19. marshadee
    marshadee Member
    57
    if u do want to rev to 6000rpm put the car in 1st gear and hold the clutch down, then it should allow you to rev more. Thats the same with mine.
  20. Lloydie22
    Lloydie22 Member
    62
    9
    I dont have a clutch peddle mate!!
  21. marshadee
    marshadee Member
    57
    Oh I see. Sorry mate, mines a manual
  22. VAG_BADGER
    VAG_BADGER Ricers in the rear view!
    100
    Reciprocal weight strain on the engine internals whist there is no load on the crank damages engine components. It also allows the engine to over-rev because there is no load. The limiter is there to stop people over revving the engine and throwing a rod, I've seen it happen. It's also there on diesels to cheat particulate regulations during MOT tests preventing the dumping of fuel at idle.
