S4 Xenon Question
nemo2182 Jan 26, 2011
  1. nemo2182
    nemo2182 Member
    130
    Ive recently realised how poorly adjusted my xenons are. Considering they are meant to be considerable better than standard Halos, mine only seem to pitch about 10ft from the bonnet . Now I think they need adjusting, but after a little surfing, seems that lowering the car messes the system up?? I dropped mine 50mm a good year or so ago, and havent noticed mine auto adjusting (moving up and down) since, so think mine r playing up. Now, I also know there are some manual adjusters on the lights that can change the horizontal and vertical pitch. Is this easy enough to do?? or are there some other 'tricks' I can do to make these better??
  2. aragorn
    18,579
    868
    You need to check the xenon control unit for faults first off.
    You can manually realign them, but you need vagcom to put the control unit into setting mode before you do so.
  3. nemo2182
    nemo2182 Member
    130
    Hello mate, i can always rely on you to respond......
    Do I need full Vag com, or can I do it through the unactivated version. i.e. I havent paid £100 to ativate it.
  4. aragorn
    18,579
    868
    Not sure to be honest. You can certainly read the codes with your standard version.
  5. unfortunately the lite version doesn't allow for xenon setup only the code reading
  6. hardhitter
    hardhitter Member
    138
    The xenon lights have a yaw sensor for adjustment of the light angle. So lowering would have some effect on it.
