s4 xenon headlight issue
therealnovaboy Sep 28, 2009
  1. therealnovaboy
    therealnovaboy Missed A Gear
    43
    my s4 (98) headlights are aimed too low. am i right in thinking these have auto leveling on them. should i adjust them using the manual adjust or could it be the case that the auto leveling is not working. how can i tell if they are working. note their is no codes up when vag-com was pluged in.
    i had a thought the other day that the headlights were removed when the timing belt was done and the auto leveling not been reset. could this be the case?
    basicaly i dont want to go adjusting them to find out the auto leveling (if there is one) is just not working/needing reset.
    thanks in advance.​
  2. aragorn
    18,297
    804
    theres a mode on vagcom that sets the lights to their default position, then you can manually align them with the twisty knobs on the light unit, then they go back to auto.
    Check the little linkages on the wheels arent siezed or detached too.
