S4 windscreen-washer-bottle leak.
Dan Gliballs Oct 21, 2007
  1. Dan Gliballs
    Dan Gliballs Active Member
    1,568
    Hi all :icon_thumright:
    No wonder the warning light is flashing on the dash,.......................when I fill the reservoir up, it all drips straight out the bottom again (relatively quickly) :bye:
    1999 B5 pre-facelift S4.
    Am I correct to assume that the sensor might be mounted from the bottom/near the bottom? Could a plug/sensor have vibrated its way out?
    As this is an S4, shall I also assume that it's an absolute cnut to GET to??? LOL
    Cheers in advance :thumbsup: :salute:
  2. stapo69
    stapo69 All hail the mighty quattro!
    969
    Not too bad to get the bottle out. Had to take mine out the other week to take my ABS module off. Need to go through your arch liner. Jack her up, remove the million screws holding the liner in and pull that out the way, 2 bolts inside there holding the bottle and 1 inside the engine bay at the top. Then the 2 pumps just pull out. Unclip the connector blocks and hoses and with a bit of gentle persuasion she'll wiggle out. Easy job. Think mine's got a bit of a leak too, wasn't sealing too well around the lower pump, bit of cracking there. Bit of silicone'll sort that for now!
  3. andybnwc
    andybnwc Member
    752
    I had the same problem turned out to be a cracked light washer motor housing i took it out cleaned it and re sealed it , job done all in under an hour
  4. Dan Gliballs
    1,568
    Many thanks chaps :beerchug: :beerchug:
  5. johnyj
    johnyj Member
    264
    does anyone elses washer water smell like old eggs when you spray it. i use washer fluid not just water
