S4 Vs Boxster 70-145mph
SonicDeathmonkey Jun 8, 2008
  1. I was "on the track" the other day, when a boxster was in front of me, both pootling along at 70. I put my foot down to overtake and he pulled out behind me, where he stayed right up until 145 or so.
    I was not really expecting that, given the new lease of life my car has has since the new EGTs and throttle body, especially towards the top end.
    Does anyone have any smilar experience?
  2. ALPINE
    3,093
    i dont really understand what your asking.. has any 1 else had there car too 145 or has any 1 else raced a boxter?
    im not being picky im genuinly askin as i dont understand what your asking.
  3. Ok, I was asking is this normal?
    I would have thought that towards the top end I would have pulled away. After all, power to weight only goes so far. Then it's all horse power and aerodynamics.
  4. Broken Byzan
    13,237
    465
    I have never had my car that fast, 135ish is as fast as i have needed to go to prove my point so far, i really need to see what she will do one day
  5. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,775
    33
    Would have expected you to have pulled away from a Boxter.
    Were you in 6th the whole time or did you shift down?
  6. Started in 5th, I think.
    I was especially annoyed because it has been pulling so strong lately.
  7. The Slug
    The Slug Active Member
    1,869
    boxster may have been tweaked a bit??
  8. mattfinn
    mattfinn There ain't no party like an S-Club Party.
    834
    Was the Boxter standard? I know out the box they are relatively tame! Could have been tampered with.
  9. ALPINE
    3,093
    ok.... you have a s4... i have a sport... i have seen 157-8. is that normal??
    i was on the m2 private raceway (lol) playing with a m3. i would quite happly do it again to get the proof.
    i assumed the cars ment to do that speed??
  10. Blue_Thunder
    1,775
    33
    How would he know... he's got an S4! :p
  11. Blue_Thunder
    1,775
    33
    And taking a look at the following link, I very much doubt if that Porker was tweaked... £3500 for 20bhp and 20lb/ft - http://www.amdtechnik.com/products.variant.cfm?variantid=125
    We don't know how lucky we are!
    Also says on there that a standard Boxster is 250-260bhp, which is about the same as a standard S4, so if you don't have a remap, I wouldn't be too upset!
    And like you said, at that speed it comes down to power and aerodynamics. Think Porsche know their stuff when it comes to aerodynamics!
  12. aragorn
    18,438
    845
    he was also behind you, meaning hes got the advantage of the slipstream generated by your car.
    But at the end of the day, similar power output and weight, hes going to have stuck with you. Wouldnt have thaught he'd have been able to pass you though.
  13. stapo69
    stapo69 All hail the mighty quattro!
    969
    I assume it was a Boxter S, the more powerful version. I chased a normal Boxster a few years ago in my good old Rover 220 Turbo coupe, with just a bleed valve and filter, and sat up his **** to 145mph, he wasn't best pleased! Shouldn't have bought a girls car then should he.......
  14. olds_kool
    olds_kool Active Member VCDS Map User
    1,093
    14
    alpinehead, i think your speedo needs fixing?
  15. stapo69
    969
    Yeah, maybe a little out.... don't 1.8ts do like 130mph max? 140ish in a sport?
    I got my old evo 6 reading 165mph on the speedo and they're limited to 155mph. Private road of course.......
  16. GSB1
    GSB1 Member
    283
    Last time I played with a Boxster S I came off very much the better.
  17. DavidR
    DavidR Active Member
    1,296
    I'm not surprised by this at all...
    I spent a summer in Europe a few years ago with my B5 S4 (330bhp) my friends EVO 4 (300bhp) and a 911 964 (250bhp).
    The 911 would keep up with both to 160mph.
    The 911 (and boxster) produce all of their power at the top end and being normally aspirated they can do it for hours and hours... Plus they are both very aerodynamic with a very low front end drag CE. Added to this Porsche are pessimistic with their power figures (most make more than they should)
    The S4 on the other hand isn't that aerodynamic, produces more torque than power and falls away at the top end due to the small turbos and heat soak. They are fast in gear - but strung out to high speeds the power degrades.
    My S3 was heavily modded to make 280bhp and 335lbft - it wouldn't do it for long though (despite several intercoolers) - I would guess that on track it lost 30bhp and 50lbft after a few laps.
    My 993 911 has 285bhp and 260lbft and is significantly faster than the S3.
    Don't beleive the figures and the hype - a proper NA car will be a lot faster than the data suggests - as you have found out.
  18. Well the moral of the story is I need more Bhp. How amI going to sneak a pair of new turbos under the wifes nose????
  19. naefeart
    naefeart Bonkers
    168
    39
    I'm assuming your S4 is standard?
    A Standard new shape boxster is 240bhp (2.7) and the S is 280bhp (3.2).
    If it was the S behind you, I'm more than happy that he stayed with you up to 145mph. Tbh I would even expect that an S has a higher top speed too.
    N
  20. The Slug
    1,869
    ooh that reminds me..cant wait to pickup the NA beast haha!
  21. ALPINE
    3,093
    pass mate... if its anything like my mk2 golfs speedo it prob does. shame i didnt have my tomtom on. (not that i was stairing at the speedo at that speed) i can assure youit was deffo past the 150 mark.
    :icon_thumright:
  22. hiltoa
    hiltoa VAG erfahren
    298
    My qs (180bhp) is pretty much maxed out on the level at an indicated 147ish.
    I have slightly smaller radius tyres to standard so my speedo will be touch more optimistic than normal.
    Without GPS to confirm, I'd guess somewhere around a true 140, which seems about right given the official figure when new was 145.
    Unless it's tweeked, a normal 1.8T 150 should push around 135 max.
  23. ALPINE
    3,093
    im seriously intreged now. i assumed the 1.8ts done that sortta speed, sware down i had that speedo past 150mph, it would be very foolish of me to try and blag you guys who all own the same car!!! lol a few of my mates have been tellin me my cars rapid, i compleatly mince my m8s 05 a3 1.8t, and can keep up with my other mates scoobi. im starting to think my car is not standerd from what you guys are saying. the turbo has been changed on it on the past, could it be possable i have a ko3s? all i have done is a cold Ram air induction, forge rdv, n75j valve. but even a ko3s is only going to give me 30bhp?? rolling road time i thinks, i need to get that speedo round to 150 on the rollers for an accurate speed. Its deffo going to be on rollers for that as i got 3 points yesterday! ooppps.
  24. Well, I was still pulling relatively strong at 145... Never gone head to head with any other A4/S4 though, so it's difficult for me to say how they would compare, but I guess not too well is the answer.
  25. Blue_Thunder
    1,775
    33
    But you won't have any wind resistance on the rollers, so it would be pointless.
    I'd be able to hit 200 on the rollers with mine!
  26. ALPINE
    3,093
    true true... well next time im on that "private road" again i will get some 1 to take a pic of the satnav next to speedo. lol
    Very intersting tho.
  27. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    I had my 180bhp 1.8tqs up to a 145mph on a track, long slow dip and a slight rise, took my foot of the gas as it was getting a bit scary.
    hill will have assisted a bit but sure it would get to 150 with some more balls on the same road...I mean straight [cough]
  28. hiltoa
    hiltoa VAG erfahren
    298
    Maybe the drag from my 245 tyres slows me down a tad at full chat.:think:
    Will have to swap back to the Boleros and 225s and see what I can max at between 'Galgenkopf' and 'Antoniusbuche'... ;)
