s4 transmission oil change Qs
therealnovaboy Feb 9, 2010
  1. therealnovaboy
    therealnovaboy Missed A Gear
    43
    I was if anyone new the service interval for changing the rear diff oil ? I cant find this info anywhere.
    Should the gearbox oil be changed at the same time or is it a matter of only checking the level and topping up where neccessary?
    Also is there a drain plug on the diff to drain the oil or do you just have to pull out the shafts?
  2. aragorn
    18,609
    871
    I suspect like the gearbox itself Audi regard it as a "filled for life" component.
    I'm sure there is a drain plug on the bottom.
