S4 Tracking....
AndyC Oct 24, 2011
  1. AndyC
    AndyC Moderator Staff Member Moderator
    719
    been fiddling with tracking on my car as we have some laser kit at work..
    for some odd reason I decided to set the front toe to parallel, at the time if felt tighter.....
    4 weeks down the line it had started to feel **** and annoy me,
    so I reset to 2.5mm toe out and it feels a ****e load better........
    free upgrade!
  2. aragorn
    17,956
    701
    audi specify 10minutes toe out per side on the front and slightly more on the rear.
  3. AndyC
    719
    without looking it up what is 10mins in MM
  4. aragorn
    17,956
    701
    I think it depends on the wheel diameter?
    A quick look online suggests that 2.5mm on a 17" rim is almost exactly 10mins.
  5. AndyC
    719
    not considered the wheel dia' before tbh. but its the distance about the pivot I guess
  6. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    the toe out helps drag the fat lazy agricultural quattro system round corners.
    I personally use less than spec but not as much off as being zero (parallel).
    saves the front tyres and gives a bit more neutral handling with the appropriate rear adjustment
  7. aragorn
    17,956
    701
    Toe out makes any car feel more lively.
    Obviously theres a balance against tyre wear and as such most ****/non-performance cars will specify very little, and really **** ones designed for old farts that cant see will even have toe in to make the steering numb and the car unwilling to turn so they dont end up wandering around the road!
  8. bmarshall
    bmarshall Member
    Toe out will cause the front to wander or dart when driving in a straight line. A few mm of toe in is the best and reduces tyre wear.
    Did you check the rear toe? It's adjustable with concentric bushings.
  9. AndyC
    719
    of course
    although toe in on the a4 caused tire wear!
  10. aragorn
    17,956
    701
    toe in makes the car feel numb and pretty crappy tbh.
    Audi specifies toe out for very good reason!
