S4 - Timing chain................snapped
nickb834 Apr 13, 2014
  1. nickb834
    nickb834 Member
    78
    So - it's finally happened, after 111k miles and 3 and a half years - the timing chains have snapped on my S4........
    No idea of the internal damage so dunno if valves have smashed holes in pistons or whether pistons have bent valves or even all of the above, but, having prepared for this eventuality it's not come as a great shock.
    Things may have moved on a bit in the last few years so before I break it for parts it's worth checking, does anyone know of any reasonably priced repair options?
    For eg - any 2nd hand engines kicking about known to be good (I doubt it - as it's usually the engine that kills an S4 off - or a tree!) OR perhaps any Audi tuners offering a recon engine fitting service?
    In all probability I'll break the car (RNS-E and DVB Tuner have already gone) the front wings are gone (rusted from inside out on arch lip) and one of the doors has started to go - but, there's this lot to go as a starters:
    • full recaro leather, electric adjustable, front heated, carbon trimmed interior up for grabs.
    • Interior dimming mirror
    • Dimming wing mirrors
    • Front and rear bumpers (paint code LZ9W - Rear has parking sensors fitted - non Audi by previous owners)
    • HID Headlamps
    • Front fogs and trims
    • Auxilliary rad (OSF - barely 12 months old) - NSF has corrosion so not worth fitting
    • 2 x Delphi alternators (1 as a spare, 1 was fitted to car 12 months ago)
    • 5 x wheels (need a refurb - which I might get done) with 4 x Michelin Pilot Sport 3's (1 worn on shoulder, other 3 about 4mm's tread left) and a Toyo Proxes T1R as spare
    • 8 x coil packs - only 20k miles on these
    When / If I decide to break this car I'll put it in the for sale section....
    Nick
  2. S3 GAZ
    S3 GAZ Member
    381
    17
    Maybe a daft question but if we're preparing for this day why did you not get the chains replaced before this happened?
  3. nickb834
    nickb834 Member
    78
    Have you seen the cost?! It's an engine out job, whilst the engine is out you may as well do the clutch and dmf. Be lucky to see change from 4 grand - on a car that's not worth much above £5k!
    The timing chains on an S4 are at the back of the engine and absolutely cannot be got at with the engine in situ, IIRC the kit of parts is well over £1500 - never mind the labour! For eg have a look at JHM's kits for this JHM Timing Chain Service Kit for B6-B7 S4 - INTERMEDIATE - JH Motorsports Inc. - -- JHM. Shifting
    Most garages won't touch these cars - try getting a clutch done for eg at a local independant and they won't touch em so you're in specialist territory or main dealer hell!
    And, most importantly of all - now I can justify using man maths a B7 RS4 :p
  4. THQuattro
    THQuattro Site Sponsor Site Sponsor Team Panther Team V8 Team V6 VCDS Map User Gold Supporter Team Silver Audi RS4 Audi S4 quattro Audi A4 Audi Cabriolet Owner Group S-line owners group Team Avus Silver saloon Manual
    1,634
    1,102
    Onwards and upwards mate. RS4 luvvly.
  5. S3 GAZ
    S3 GAZ Member
    381
    17
    Oh well didn't appreciate the cost if doing the chains.
    Please don't let the rs4 suffer the same fate or have u factored in the maintenance cost of such a beast
  6. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,138
    cost of doing chains on an s4 is expensive
    all the more reason to protect against this and fit the pre oiler to stop the chain rattling on start up and breaking the chain guides
    which in turn snaps the chain
  7. THQuattro
    1,634
    1,102
    Hi whats the life of a S4 chain and how big a job is the chain pre oiler.
  8. BakPak
    BakPak No Gear
    957
    137
    43
    Yeah when do audi recommend the timing chains are replaced?
  9. p1tse
    p1tse Member
    797
    24
    Sorry to hear
    Out of interest did you have longer than usual chain rattle on start up and frequency?
    What service regime was it on and type of oil used?
    Any tell tell signs it may have been coming?
  10. dualmono21
    1,138
    audi reccomend changing the chain and gears at 300,000 miles
    the pre oiler system time to fit is a little dependant on what size you fit it and where
    im in the middle of doing a write up with pictures of how mines has been done
    Av4nt likes this.
  11. THQuattro
    1,634
    1,102
    So 111k is a third of expected life, not good.
  12. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,246
    189
    I'd be in tears!
  13. dualmono21
    1,138
    there are some in the states with a little over 60k on them when they have gone
    a couple have been done by audi as goodwill gestures but clearly the parts where not well designed as against the rest of the engine
    the best way to protect against it now is the pre oiler system , there have been no reported failures since anyone fitting the system has had one fitted
  14. THQuattro
    1,634
    1,102
    Who does these pre oiler systems.
  15. dualmono21
    1,138
    there are a few companies who make pre oiler systems
    they are mainly fitted on very high performance engines or old classic cars which are again usually raced or rallied
    moroso , accusump , amsoil , oilamatic to name but a few who make systems
  16. nickb834
    nickb834 Member
    78
    Chain rattled for just less than a second on startup - did it every morning but once it had started for the day it didn't do it again.
    The engine was running Fuchs Titan Race Pro S 5w40, and the oil was changed circa every 8k miles which is about 12 months for me.
    There was absolutely nothing warning me that this was coming - what I would say is, it let go when it was in the process of getting thrashed - but then what's the point of pootling a 300+ hp v8 :p
  17. nickb834
    nickb834 Member
    78
    I've though of fitting one a few times - should, woulda, coulda! I'd be intrigued to know if the RS4 (B7) suffers the same with it's chains - I've not looked tbh as I'm a few months off having the necessary wedge to find my own.
  18. nickb834
    nickb834 Member
    78
    Yeah it's an easy call with an RS4 - leggy ones are still fetching 14k, mint lower miles are circa 20k - it's a no brainer to do 3k worth of maintenance on a 20k car - but, it's equally a no brainer not to bother on a 5k car.
  19. S3 GAZ
    S3 GAZ Member
    381
    17
    suppose when u put it like that
  20. p1tse
    p1tse Member
    797
    24
    How long have you owned and mileage covered
    Sounds like you looks after it
    As it sounds like you had decent oil, would normal usage cause chain guide wear or is it really just at start up ?
    Sounds like audi need to sort something out
  21. nickb834
    nickb834 Member
    78
    I'd had the car 3 1/2 years and done about 30k miles in it, it's very well documented the chain tensioners going on B6/7 S4's.
    The noise at startup doesn't cause the wear, the wear causes the noise at startup. The chain guides go, then the tensioners and then boom snappage! The time this takes to happen is a function of quality of oil and frequency of changes and usage and pi55 poor design in the first place.
    What I would say is - if you ever consider buying a car that's been on long life service schedule then walk away - there's no way in hell no matter how good an oil is that you can go 20k between services. For eg - this S4 of mine was switched by me from time and distance intervals to variable based on driving. The car looked at the various parameters such as fuel consumption vs load and so on and told me roughly every 8k miles that it wanted a service - can you imagine doing 12k miles beyond that on a time and distance schedule on some VAG group Quantum 504 oil? shudder!
  22. p1tse
    p1tse Member
    797
    24
    I'm a recent new owner
    66k and has been on long life, like a lot of the other ones out there
    First week of ownership I took it off variable to what I will do as annual
    And running on Fuchs Titan pro too
  23. dualmono21
    1,138
    the noise at start up is caused by the thinning oil leaking from the hydraulic tensioners (some manufacturers new ones are fitted with a one way valve so this cannot happen )
    the one second rattle on start up .... causes the chain to slap the plastic wear guides and wear them thin in particular spots
    when the chain guides eventually fail ..... this causes the chains to go slack and the tensioners to work even harder to try to take up slack and eventually the tensioner snaps
    good oil definitely helps and shorter service intervals
    or if you want to take it out of the equation fit a pre oiler system to pump up the tensioners before you start the engine
    this gets rid of the chain slap ... which doesn't wear your guides , which doesn't overexert your tensioners
  24. p1tse
    p1tse Member
    797
    24
    I'm aware that there are some which have suffered from the cam chain issue resulting a wrote off
    Is it more common on b6 due to different guides?
  25. dualmono21
    1,138
    i think it is more common on the b6 but only because of age related wear not design function
    the guides on the b7 are slightly harder plastic but they still wear when a chain slaps them ...
  26. p1tse
    p1tse Member
    797
    24
    How about the older s6, a8
  27. dualmono21
    1,138
    not the same engines as some of the old s6 and a8 engines are cam belt not chain
    the bbk engine in the s4 is unique it was purpose designed to be shorter than the old a8 engine to fit in the engine bay of the b6 chassis
  28. haytch75
    haytch75 Member
    176
    17
    so Dualmono21......as I understand it the B7's are a little less prone due to slightly harder plastics and fitting a pre-oiler system prevents further wear to the point where it goes bang, is this right?
    If this is the case I assume it would make sense to aim for a B7 with a top quality history and fitting a pre-oiler ASAP.
  29. Ian2012
    Ian2012 Active Member
    473
    29
    I worked at an audi dealer when the B6 S4 came out, the first one we had went out on road test after it's pdi with the tech at the wheel, came back an hour later on low loader with a blown engine, had less than 10 miles on the clock, took audi a while to supply a new engine. At the time they either went bang instantly or were ok, ours wasn't the only one.
    The cam chain thing was much lauded as being a big step forward as they never need to be changed.
  30. dualmono21
    1,138
    b6 or b7 i really dont think it matters
    im sure in future you will see just as many b7,s suffering the same problem as b6,s
    the pre oiler makes all the difference as does regular oil changes , this is not a car you can afford to skimp and save on as regards oil quality
    a low mileage car would be more expensive than something with some miles on it but evidence of a good maintenance history is paramount for these cars
    this isnt the same as a full dealer history , unfortunately now its becoming increasingly common to fake service books with audi service stamps
    it is however a lot more difficult to fake a vat reciept for individual service items
    dont buy the cheapest one you can get , buy the best one you can afford it will pay dividends if you keep the car for a while
  31. haytch75
    haytch75 Member
    176
    17
    Cheers mate. I'm keeping my eye out for my perfect S4 comes up. When it does it will be impeccably maintained and a keeper.
  32. haytch75
    haytch75 Member
    176
    17
    Sorry for the thread hijack Nickb834 and even sorrier for the crappy news mate.
    Have you managed to recover much through breaking?
  33. Ian2012
    473
    29
    The other key thing i remember at the time is the master tech who i worked with at the dealer, wasn't impressed with the change to longlife servicing, i vividly remember him rubbing longlife oil threw his fingers and saying it's ****.
    proof of the pudding is i know run 2 cars with same engine but one has been run on longlife (until we got it) and one not, the one that hasn't been run on longlife is as sweet as a nut hot or cold, burns no oil in 10k. the other noisy when cold and almost grouchy too when not warmed up this engine uses 1.5 litres of oil per 10k miles. Master tech was right in my book.
  34. dualmono21
    1,138
    again i know cars which both do and dont use oil
    whether or not this is down to previous history i really couldnt say but personally i agree with the thoughts on long life oil
    however some very low miles b7 owners reporting that there cars do use oil
    a friend of mine has the exact same car as mine even down to the colour my car has 70k on clock and doesnt use oil
    his has 64k and does use oil
  35. Mike.M
    Mike.M Well-Known Member
    2,510
    170
    Sorry to hear the news........I would buy a cheap but decent 3.0 quattro SE and transfer all the S4 kit across.
  36. GeoffDunk
    GeoffDunk Well-Known Member Team Panther Audi RS4 quattro Audi Avant Owner Group
    1,300
    392
    I can only assume homework not fully done or a dodgy inderpendant.
  37. lemonslap
    lemonslap New Member
    23
  38. cobraBLACK
    cobraBLACK Chocolate? It's doo-doo, baby!
    367
    19
    Do the B8s have timing chains too?
